Description box not appearing in "Build
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Thu May 29, 2014 10:43 pm
A description box I included appears and functions just fine in "View last tour built" but when I actually build the tour it does not appear at all. Everything else appears fine but the Description box.
Even when I add a simple button and have that button's action set to "Display the current spot description" the button will show but not the description.
Ed
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
Re: Description box not appearing in "Build
by mediavets » Thu May 29, 2014 11:12 pm
ERR wrote:A description box I included appears and functions just fine in "View last tour built" but when I actually build the tour it does not appear at all. Everything else appears fine but the Description box.
Ed
What do you mean by 'when I actually build the tour'?
To be able to use the View last built tour button you must already have built the tour.
Are you saying the description feature doesn't work after uploading the tour to your web server?
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Fri May 30, 2014 12:10 am
Yes I just realized that when you click "build tour" that it is actually building the tour. I thought it was a "preview" of some sort and the "view last tour" called it up. I realized after I deleted the files that it was the actual build :/
I have not loaded it to a server yet but, when I preview the build in PTP everything works swell. When I access the "index".html from the folder itself, then the "desctiption" fails to appear.
Does the tour need to be on a server to display that?
Thanks,
Ed
Liked in: 227 posts
by Destiny » Fri May 30, 2014 12:17 am
"Does the tour need to be on a server to display that?"
No... but you do need to use the View Last Built Tour or the krpano Testing server...
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Fri May 30, 2014 2:04 am
That must be it.
Thanks again Destiny.
Peace,
Ed
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Fri May 30, 2014 2:52 am
Uploaded it to the server and all is well. Thanks again for the advice.
I'm curious as to why everything but the "Description" box didn't work locally sans "view last built tour" or KRpano? What element is missing for that one thing? Hmmmm...
Peace,
Ed
Liked in: 227 posts
by Destiny » Fri May 30, 2014 3:10 am
It should work.. Its Javascript based which means it has to work via server protocols which is what the View Last Build is.. also same with the krpano testing server... What you might try, is remove the cache file generated by PTP during the build. Its a new file option added in the latest version.. Also empty your browser cache.. Then rebuild your Tour and try again..
by mediavets » Fri May 30, 2014 6:17 am
ERR wrote:Uploaded it to the server and all is well. Thanks again for the advice.
Peace,
Ed
See: http://www.autopano.net/wiki-en/action/ ... ur_offline
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Fri May 30, 2014 12:17 pm
=D
