No Nadir patch when using Cube Faces..
Liked in: 227 posts
by Destiny » Tue May 27, 2014 8:23 am
PTP V2.1.1
Mac Mavericks.
Its still not possible to add a Nadir Patch to a pano via the Tour Tab when using Cube Faces..
Likes: 13 posts
Liked in: 118 posts
Re: No Nadir patch when using Cube Faces..
by bdd » Tue May 27, 2014 8:59 am
Destiny wrote:PTP V2.1.1
Mac Mavericks.
Can you describe exactly your problem ?
Can you select a nadir patch in the panorama properties ?
Is the patch field displayed in Panotour ?
Is the patch displayed in the "3D View" preview once the patch field is filled ?
Is the patch generated in the tour ?
We checked on Windows, Linux and MacOS, and all is working well on our side.
Liked in: 227 posts
by Destiny » Tue May 27, 2014 9:20 am
emm.. Now the Nadir Patch shows.. No idea why it did not show before in either the 3D view or the build. But now the % of size has issues.. I put it from 10% to 80% and no change in size.. It defaults at 20%.... When I change the size its does not change in the 3D view or the build.. I tested it with several new test from scratch..
Likes: 13 posts
Liked in: 118 posts
by bdd » Tue May 27, 2014 9:29 am
Destiny wrote:emm.. Now the Nadir Patch shows.. No idea why it did not show before in either the 3D view or the build. But now the % of size has issues.. I put it from 10% to 80% and no change in size.. It defaults at 20%.... When I change the size its does not change in the 3D view or the build.. I tested it with several new test from scratch..
OK, reproduced.
I will enter a bug about it. On cube faces, you cannot change the patch settings.
If you save your project, close PTP, reopen it. Then your previous changes are applied.
Liked in: 227 posts
by Destiny » Tue May 27, 2014 9:41 am
Gérald , now I start again, add the Nadir Patch Logo, and this time it does not snow again in the 3D view or the build.. No idea why.. It seems to be very iffy...
Likes: 13 posts
Liked in: 118 posts
by bdd » Tue May 27, 2014 9:44 am
Destiny wrote:Gérald , now I start again, add the Nadir Patch Logo, and this time it does not snow again in the 3D view or the build.. No idea why.. It seems to be very iffy...
When it worked, was it with the same png file ?
Liked in: 227 posts
by Destiny » Tue May 27, 2014 9:47 am
Yes Gérald... I only have one Nadir Logo.. Its a PNG...
Likes: 13 posts
Liked in: 118 posts
by bdd » Tue May 27, 2014 10:08 am
Destiny wrote:Yes Gérald... I only have one Nadir Logo.. Its a PNG...
Did you build the tour before trying to patch the nadir ?
Liked in: 227 posts
by Destiny » Tue May 27, 2014 10:11 am
No.. I just added the cube faces, then add the Nadir patch logo then build the test Tour. No menu or other plugins..
Liked in: 227 posts
by Destiny » Tue May 27, 2014 10:15 am
.... I did tried again and now its working.. very iffy very strange...
Liked in: 227 posts
by Destiny » Tue May 27, 2014 10:19 am
.... and again I try and now the Nadir is there and ALSO the % of size works.. oh hum... :rolleyes:
Obviously a big buggy...
