Sound File Bug PTP v 2.1
BrianLR
by BrianLR » Fri May 23, 2014 3:36 pm
I want to remove some Background Sound on two panos but the file name does not appear in the Background sound file window. If I delete the files from the sound folder in PTP I get an error message on running the tour. If I rebuild the tour the files are back in the folder again. How can I get rid of the sound?
Likes: 13 posts
Liked in: 112 posts
Re: Sound File Bug PTP v 2.1
by bdd » Fri May 23, 2014 3:49 pm
BrianLR wrote:I want to remove some Background Sound on two panos but the file name does not appear in the Background sound file window. If I delete the files from the sound folder in PTP I get an error message on running the tour. If I rebuild the tour the files are back in the folder again. How can I get rid of the sound?
Then, retype something, whatever, in the sound field in the panorama properties
Unselect the pano.
Reselect the pano.
Empty the field.
Rebuild
BrianLR
by BrianLR » Fri May 23, 2014 5:35 pm
Gérald,
I tried that it worked briefly as long as the new text was in the field, but once I closed and reopened the Tour file it reported that the text (file) was not available and then the problem returned. When I tried adding another true audio file, the old and the new file played together, then I deleted the new file and the old one played again.
Then I found that I had a sound hotspot on the pano and deleted that, and all is OK.
Thanks,
Brian
