shovay wrote:Panotour 2-2.1
Windows 7 x64
Panotour 2 or 2.1
What do I do?
New default project
1 import the icon into my library.
2. under the style tab, and viewers tab I activate either the webvideo box
3.Crush Programm
Create a new point or polygon or simple button Results same!
If you want I can make a dump of the program after the crash?
mediavets wrote:shovay wrote:Panotour 2-2.1
Windows 7 x64
Panotour 2 or 2.1
What do I do?
New default project
3.Crush Programm
What icon are we talking about here? Is this is custom graphic you wish to use for your hotspot?
shovay wrote:mediavets wrote:shovay wrote:Panotour 2-2.1
Windows 7 x64
Panotour 2 or 2.1
What do I do?
New default project
3.Crush Programm
I use the standard icons
Create a new hotspot or polygon or simple button Results same!
