Adding Nadir Mac From Tour Does not work...
by Destiny » Sun May 18, 2014 9:28 am
Hey..
I asked Andrew M to test on Windows, adding a Nadir using the option from the Tour Tab.. It seems to work on Windows but not using a Mac, Mavericks.. Using the Logo option to add a Nadir image from the Styles Tab works well..
dseixas
Re: Adding Nadir Mac From Tour Does not work...
by dseixas » Tue May 20, 2014 11:56 am
I had the exact same problem.
It only happened when I used the "import cube-box" options to load the panorama file. So my workflow was like this:
Load panorama file (1 image)> export cube-faces > [do something awesome with the cube-faces] > replace panorama file with modified cube-faces > export panorama file > replace panorama with last exported panorama file
And then you get to add the Nadir patch
BR
by Destiny » Tue May 20, 2014 12:18 pm
Well that's confirmed.. The Nadir now appears.. Well done.. ;)
It seem this bug is only when using cube faces which is what I mostly use...
So Andrew (mediavets), can you please test using cube faces on Windows...
Thank you
Destiny....
Likes: 14 posts
by bdd » Tue May 20, 2014 12:21 pm
Destiny wrote:Hey..
OK, I reproduce the bug on Windows, with a panorama made with a cube faces import.
Andrew did not reproduce it because he may not import cube faces.
I open an issue about this bug : n°3527
by mediavets » Tue May 20, 2014 12:40 pm
bdd wrote:.
Correct - I never import cube faces.
