Floor Plan at ipad do not close
rruiz
Liked in: 5 posts
by rruiz » Sat May 17, 2014 12:04 pm
If I open the floor plan using the tool bar of my pano after moving between hotsposts, floor plan can´t be closed until I re-open a new crome tab. I am using the Kolor icontrol preset.
What I am doing wrong ?
Liked in: 226 posts
Re: Floor Plan at ipad do not close
by Destiny » Sat May 17, 2014 12:12 pm
Hi...
It might be due to having another button, hotspot or even a Logo under the X close.. Its a known bug I reported a long time ago.. If not.. then I do not know....
rruiz
Liked in: 5 posts
by rruiz » Sat May 17, 2014 12:21 pm
Destiny wrote:Hi...
You are correct , it is under de X close
