Really annoying - is it a bug? PTP forget the Links.
Frenchev
Liked in: 3 posts
by Frenchev » Fri May 16, 2014 10:51 am
Really annoying bug. Sometimes, I don't know how, the PTP forgets the Links between the images. And all hotspots from one panorama are linked to the next one - see the picture.
Am I doing something wrong? Does this happen to you? What can I do? Now is really a lot of work to link all the hotspots to the correct panoramas.
Thanks!
Liked in: 226 posts
Re: Really annoying - is it a bug? PTP forget the Links.
by Destiny » Fri May 16, 2014 11:06 am
Hi...
Even since the first Alpha and Beta testing, I have never heard of that happening..
I am guessing you drag to link... I use the "Go to panorama or Group" option.. Never had a an issue but there again, I have never had that many hotspots to link.. You can correct your links using this method.. It shouldn't take too long..
All I do is add the hotspot, make sure its the correct hotspot, then I link it using the "Go to panorama or Group" option..
Likes: 13 posts
Liked in: 112 posts
by bdd » Fri May 16, 2014 1:40 pm
Frenchev wrote:Really annoying bug. Sometimes, I don't know how, the PTP forgets the Links between the images. And all hotspots from one panorama are linked to the next one - see the picture.
Thanks!
We reproduced such bug this way (it will be fixed in next release ) :
- Select a panorama containing some hotspots linked to different panoramas
- Go to the Style tab
- Modify the spots style of the spots of the selected panorama
So the advice, while waiting for the fix, is to unselect everything before going to the Style tab.
Frenchev
Liked in: 3 posts
by Frenchev » Sat May 17, 2014 10:55 am
Thank you Kolor Team!
