Bogdan wrote:I can see the description in the project but not locally.
I added in each panorama one picture from the hotspot editor then Picture Spot - Action - Plugin Description - Display current spot description
On the View last build tour it's ok. But like i said it's not working from local server
What could be?
mediavets wrote:Bogdan wrote:I can see the description in the project but not locally.
What could be?
What do you mean by 'local server'?
Bogdan wrote:mediavets wrote:Bogdan wrote:I can see the description in the project but not locally.
What could be?
From my computer
Bogdan wrote:The description on the image is still not working on the web server. Also the fullscreen button from control bar.
Here is my virtual tour : http://www.tururivirtualeprahova.ro/Par ... v-c21.html
Select the 4-th panorama to see the pictures with descriptions that not working
mediavets wrote:Bogdan wrote:The description on the image is still not working on the web server. Also the fullscreen button from control bar.
If you are using an iframe to dispaly the tour on a web page you need to add the fullscreen attribute.
See: http://www.autopano.net/wiki-en/action/ ... Publishing
Bogdan wrote:mediavets wrote:Bogdan wrote:The description on the image is still not working on the web server. Also the fullscreen button from control bar.
And how about the description on the picture?
Bogdan wrote:Could somebody help me with this problem? I really need to have the descriptions on the image.
mediavets wrote:Bogdan wrote:Could somebody help me with this problem? I really need to have the descriptions on the image.
As I understand it there is no problem when you view the tour offline using the View last built tour... button.
Is that correct?
If so, might suggest that the issue lies in the coding of your web page on which you are embedding the tour.
But it still doesn't work, nor does the fullscreen function, if I access the tour directly via:
http://www.tururivirtualeprahova.ro/emb ... Zoo-Bucov/
Are you sure all the tour files got uploaded correctly and have the correct file permissions?
Perhaps there's something 'odd' about your web server configuration/setup?
Bogdan wrote:When i see the tour offline using the View last build tour button is working perfect.
But it's not working if i use the .html file from my computer
and neither through my website.
mediavets wrote:Bogdan wrote:When i see the tour offline using the View last build tour button is working perfect.
OK.But it's not working if i use the .html file from my computer
That's understandable. Some features in PTP 2.x won't work unless the tour is delivered via a web server because of browser security features. When you view oflline using the View last built tour button the tour is delivered via a lightweight built-in web server.
http://www.autopano.net/wiki-en/action/ ... ur_offlineand neither through my website.
That's what I don't understand.
Could you try building the tour into a new target folder and then uploading the tour as-is - everything that PTP puts in the target folder when you build the tour - to a new directory/folder on your server and see if it works then.
