Splash Screen
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
Splash Screen
by FunkyPunky » Wed May 14, 2014 12:15 pm
just tried PTP 2.1 test version on a mac, output local on my computer.
If i set up a splash screen the defined image is not showen in the tour, but all menus and controls are hidden. If i click in the browserwindow all menus and contols are visible.
If i enable the overlay, the overlay is visible and the image is still hidden.
If i enable "automaticly close after ... seconds" the image is visible.
may be a bug...?
Regards
Re: Splash Screen
by mediavets » Wed May 14, 2014 12:26 pm
FunkyPunky wrote:Hi,
may be a bug...?
Regards
Are you using the View last built tour... button in PTP 2.x to view the tour offline?
Which browser are you using and on which OS?
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
Re: Splash Screen
by FunkyPunky » Wed May 14, 2014 12:32 pm
Yes, i used the View last built tour... button.
Browser is Firefox 28, system is OSX 10.7.5.
Re: Splash Screen
by mediavets » Wed May 14, 2014 12:52 pm
FunkyPunky wrote:Yes, i used the View last built tour... button.
The behaviour you reported is confirmed with PTP 2.1 on my Windows 7 pro 64-bit system, viewing with Firefox 29.0.1.
The 'solution'/workaround would seem to be to have the splash screen automatically close after a long time interval; clicking on the Splash screen will close it before the time set too.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
Re: Splash Screen
by FunkyPunky » Wed May 14, 2014 12:58 pm
Ok, thanks for your help!
Likes: 13 posts
Liked in: 112 posts
Re: Splash Screen
by bdd » Wed May 14, 2014 1:01 pm
The issue n°3475 is opened on this splashscreen bug.
It will be fixed in next Panotour release.
