Nadir Patch not visible
Bogdan
by Bogdan » Wed May 14, 2014 8:54 am
In my project i can see the nadir, but after building the tour is not visible.
I'm using PTP 2.1 on Windows 7 64 bit
That was happened after PTP 2 update.
Thanks.
Re: Nadir Patch not visible
by mediavets » Wed May 14, 2014 9:43 am
Bogdan wrote:In my project i can see the nadir, but after building the tour is not visible.
Thanks.
You added a Nadir patch image in panorama properties? Or a nadir Logo plugin?
Bogdan
by Bogdan » Wed May 14, 2014 9:53 am
Thanks.
Nadir Logo
by mediavets » Wed May 14, 2014 10:25 am
Thanks.
Nadir Logo
Are you viewing the tour locally using the View lst built tour button in PTP 2.x?
Or is the tour online?
Which browser are you using and on which OS?
Do I understand that you initially created the tour with an earlier version of PTP 2.x?
If so perhaps try and remove the nadir Logo plugin and then add it back again and re-build.
Bogdan
by Bogdan » Wed May 14, 2014 10:36 am
Locally and online is the same.
I'm using Mozzila on Windows 7 64 bit
I created the tour on Windows 7 32 bit and now i have Windows 64 bit with PTP 2.x 64 bit
Likes: 11 posts
Liked in: 94 posts
by bdd » Wed May 14, 2014 10:49 am
Bogdan wrote:Locally and online is the same.
As Andrew said, if you remove the logo plugin and re create it, do you still have the bug ?
Bogdan
by Bogdan » Wed May 14, 2014 10:56 am
Yes, i tried with a new project and is the same
by mediavets » Wed May 14, 2014 11:04 am
Can we see a screenshot of your Logo plugin configuration/settings, like this one:
Likes: 11 posts
Liked in: 94 posts
by bdd » Wed May 14, 2014 11:05 am
Is it possible for you to send us the file you try to set as a nadir Logo ?
Bogdan
by Bogdan » Wed May 14, 2014 11:08 am
Here it is
Likes: 3 posts
Liked in: 215 posts
by Destiny » Wed May 14, 2014 11:52 am
Sorry, but that is NOT the Nadir Patch at all.. Its a logo....
Likes: 3 posts
Liked in: 215 posts
by Destiny » Wed May 14, 2014 11:56 am
.... what you need is here....
by mediavets » Wed May 14, 2014 11:57 am
Bogdan wrote:Here it is
I don't think those settings will achieve the effect you want.
These are the settings I used, how it apers in a pano in a tour and the logo PNG file.
Does this work for you?
logo turu.ro.png (3.46 KiB) Viewed 816 times
by mediavets » Wed May 14, 2014 11:59 am
Destiny wrote:Sorry, but that is NOT the Nadir Patch at all.. Its a logo....
You can use the Logo plugin to place a nadir patch - like this:
viewtopic.php?f=92&t=22456&p=142467#p142466
Likes: 3 posts
Liked in: 215 posts
by Destiny » Wed May 14, 2014 12:01 pm
Yes Andrew.. I know.. One distorts one doesn't....
Bogdan
by Bogdan » Wed May 14, 2014 2:32 pm
So, before the update PTP, I was able to add nadir patch logo in each panorama. Just loading the .png file and was working.
by mediavets » Wed May 14, 2014 3:06 pm
Bogdan wrote:So, before the update PTP, I was able to add nadir patch logo in each panorama. Just loading the .png file and was working.
There are two main ways to add images at the nadir if your panos have a pano FOV of 360x180 and an aspect ratio of 2:1.
You can do it via the Panorama properties settings - screenshot below.
Or using a Logo plugin as we have discussed and described in this thread previously.
Bogdan
by Bogdan » Wed May 14, 2014 7:56 pm
I'm doing like in your screenshot attachament
I had some projects that worked with previous version of PTP. But the projects were made on Windows 7 32 bit. After i installed Windows 7 64 bit and open the project i was unable to see the nadir patch ( it shows only in the panorama Tour Tab)
by mediavets » Wed May 14, 2014 8:12 pm
Bogdan wrote:I'm doing like in your screenshot attachment.
If you don't see the nadir patch option in Panorama properties in the Tour section the PTP 'thinks' you pano image does not have 360x180 pano FOV and and aspect ratio of 2:1.
