No display project description
giosa
by giosa » Sun May 11, 2014 8:03 am
Panotour pro Version 2.1 64 bits windows seven i7 8 gb ram.
When I open a project, description of the project is no longer visible.
Giosa
Re: No display project description
by mediavets » Sun May 11, 2014 8:56 am
giosa wrote:Panotour pro Version 2.1 64 bits windows seven i7 8 gb ram.
Giosa
I cannot reproduce the problem.
giosa
by giosa » Sun May 11, 2014 9:22 am
If i open the project inside panotour (Home, see picture) is all ok, Image.
If i open in the folder (see image)i have the problem Image
Example, the description is not visible Image but when i build the tour the description is displayed in the browser.
Likes: 13 posts
Liked in: 112 posts
by bdd » Tue May 13, 2014 8:01 am
giosa wrote:If i open the project inside panotour (Home, see picture) is all ok, .
Example, the description is not visible but when i build the tour the description is displayed in the browser.
The description may contain a character that Panotour does not manage correctly.
I will open an issue about this problem.
But to be able to ix it we have to know which part of the description leads to it.
Could you share the project file with us ?
giosa
by giosa » Tue May 13, 2014 3:17 pm
Hi Gerald,
Where i can share the project?
Note:
When i build the tour the description is visible, not is visible inside Panotour Pro
Likes: 13 posts
Liked in: 112 posts
by bdd » Tue May 13, 2014 3:23 pm
giosa wrote:Hi Gerald,
Just share the project file, the kpt file.
You can either attach it ti a private message on the forum, or send it to me to contact@kolor.com .
zakariya
by zakariya » Fri May 23, 2014 11:11 am
Hi giosa,
This issue occurs if project name contains flowing characters ' or " .... quot or double-quotes
just remove them and your saved description will appear again.
