point spot color dont change
Fahidoz
by Fahidoz » Thu Apr 17, 2014 8:30 pm
hello,
i am having this problem .. i am doing every thing as i should ..
i am using an icon from the library select custom color and i select the color and every thing looks fine from this end
but the color don't change after exporting the tour, its stuck with the default color ..
how can i fix that?
i tried to re build every thing multiple times .. didn't seem to help
thanks on advanced
Re: point spot color dont change
by mediavets » Thu Apr 17, 2014 9:04 pm
Fahidoz wrote:hello,
how can i fix that?
thanks on advanced
Which version of PTP on which OS?
Fahidoz
by Fahidoz » Thu Apr 17, 2014 10:59 pm
PTP 2.0.1 64 bit
on windows 7 home premium sp1 64 bit
Likes: 3 posts
Liked in: 225 posts
by Destiny » Thu Apr 17, 2014 11:23 pm
Which Hotspot Icon are you using...?
Fahidoz
by Fahidoz » Thu Apr 17, 2014 11:40 pm
aged - direction (sequence)
and aged - neutral (sequence)
Likes: 3 posts
Liked in: 225 posts
by Destiny » Fri Apr 18, 2014 12:40 am
Hi..
Confirmed on Mac PTP V2.1 RC1..
Its a bug... :(
Likes: 3 posts
Liked in: 225 posts
by Destiny » Fri Apr 18, 2014 12:53 am
Do you have Photoshop..?
The only way to change the colour is via the graphic itself which is in the "spots" folder...
If you have Photoshop, I will explain an easy way to achieve this..
Fahidoz
by Fahidoz » Fri Apr 18, 2014 7:11 am
Hi
Yes i do have photoshop
What to do?
Find the icons in the exported tour and manually chang color to all of the sequence icons?
Likes: 3 posts
Liked in: 225 posts
by Destiny » Fri Apr 18, 2014 7:26 am
Hi.. This process is the only way to preserve the transparencies and the gradients of the hotspot as they were made..
1. Drag the hotspot from the Spots Folder onto the Photoshop icon which will auto open Photoshop, maintaining the size of the graphic.. If Photoshop is already open the graphic will appear..
2. On a Mac, hold down the 'command' key which is the third button in from the bottom left, next to the return long return key.. Then use your mouse to click on the actual graphic in the Layer.. It should now be selected..
3. Set the 'Foreground Colour' at the bottom left of your controls to the desired colour.
4. Hold down the 'option' or 'alt' key second in from the bottom left, then press 'delete'
Your graphic is now the colour you chose with all alpha gradients preserved. Now Save.
Test your Tour and you will see its as it was designed by Kolor but with your chosen colour...
Repeat this process for all other hotspots..
Fahidoz
by Fahidoz » Fri Apr 18, 2014 8:08 am
ok will do just that :)
thank you destiny
are you with kolor team or just a user?
alot of things posted on this forum was solved by you, if you don't work with them u should be rewarded big time for your contribution to this forum .... thanks again :)
Fahidoz
Likes: 11 posts
Liked in: 96 posts
by bdd » Fri Apr 18, 2014 8:20 am
Fahidoz wrote:aged - direction (sequence)
Aged spots are not colorizeable.
We have to fix this in the interface : do not propose a custom color when the spot are not colorizeable.
But as you see, when you change the color of a colorizeable spot, the colored spot appears in the "Spot styles" column on the left of the "Style" tab.
When you try to colorize an "Aged" spot, they are not colorized on the left column.
Likes: 3 posts
Liked in: 225 posts
by Destiny » Fri Apr 18, 2014 10:41 am
Hey Gérald
Why would it be necessary to have some hotspot with no custom colour options... Surly it would be a better option to allow all hotspot to have a custom colour.. Seems to me a confusion is being added that is unnecessary... What if I like that hotspot but the default colour does not match my theme as in the case here..
Likes: 11 posts
Liked in: 96 posts
by bdd » Fri Apr 18, 2014 12:39 pm
Destiny wrote:Hey Gérald
If someone wants to share, or sell a set of icons to be used as PTP spots, it is easier to create uncolorizeable icon.
To have a colorizeable icon, means a colored monochrome icon.
If you want to create a set of multicolor icons, it can not be colorizeable.
So yes I agree, fo the "Aged" set, we may have create a colored colorizeable set.
