[SOLVED] No hotlinks for web address?
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Wed Apr 16, 2014 10:10 pm
I have been looking all over the documentation and web but can't see how I can link a polygon or point hotspot
to a url? The only link it will make is to another pano : Action Parameters only displays "a panorama".
I am trying to design this tour so when a client clicks on a specific hotspot another (separate) web page will open.
I would expect that picking the type of link I want would appear in the "Action Parameters"?
I'm sure this is available but am overlooking it.
I'm in the middle of evaluation and if this doesn't allow me to link a hotspot to a url then I'm "in trouble".
Thank you for your help
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
Re: No hotlinks for web address?
by mediavets » Wed Apr 16, 2014 10:39 pm
ERR wrote:I have been looking all over the documentation and web but can't see how I can link a polygon or point hotspot
Configure an instance of the Point style in the Style section with the appropriate action - screenshot 1.
Then in the Tour section add a hotspot in the Hotspot Editor, associate it with the Point style you created, finally configure the Hotspot properties appropriately - screenshot 2.
Liked in: 227 posts
by Destiny » Thu Apr 17, 2014 12:33 am
Hi.. You can do two things.. As Andrews suggest, which will open a new browser window or you can link a hotspot to a Kolor Website Box and keep the web page within the Tour..
http://www.destinyvirtualtours.com/PTPV ... teBox.html
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Thu Apr 17, 2014 12:48 am
Many thanks for this help! I like the website box...SOLD!!!!
albena1
by albena1 » Mon May 05, 2014 1:25 pm
I made all of the instructions above - doesn't work. Hotlink for web (any hotlinks for outside web), logo in nadir - doesn't work.
by mediavets » Mon May 05, 2014 1:29 pm
albena1 wrote:I made all of the instructions above - doesn't work. Hotlink for web (any hotlinks for outside web), logo in nadir - doesn't work.
Welcome to the forum...
Which version of PT/PTP are you using and with which operating system?
Which browser are you using to view the tour?
Are you viewing the tour online or offline?
If offline, are you using the View last built tour... button in PTP 2.x or an offline web server?
albena1
by albena1 » Mon May 05, 2014 1:50 pm
Thanks for the questions - they explain in.
I checked the panorama on my computer (Maverick 10.9.2, PTP 2.1) when I moved it to the server - everything works :)
Thanks a lot :)
by mediavets » Mon May 05, 2014 2:19 pm
albena1 wrote:Hi,
Thanks a lot :)
OK.
This is probably worth reading:
http://www.autopano.net/wiki-en/action/ ... ur_offline
