PTP V2.1 RC1 posible html template bug...
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 8:05 am
Hey Kolor...
I notice this happening on others Tours so I checked and found it on mine too.. Is this a html template bug for something else..
There are two notices of errors the other suggest something cannot be found so it will be ignored..... The JS error only began since PTP RC1..
Not sure if its a Safari issue or something else.. I used the Web Inspector do view the errors..
Likes: 13 posts
Liked in: 115 posts
Re: PTP V2.1 RC1 posible html template bug...
by bdd » Wed Apr 16, 2014 8:19 am
Destiny wrote:Hey Kolor...
Hello Destiny,
Can you please provide some URL of tours on which you found this error ?
I did not see it yet.
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 8:36 am
Sure..
This url is your latest build V2.1.RC1 - Two errors...
http://www.destinyvirtualtours.com/PTPV ... ePano.html
This one V2 - Same two errors...
http://www.destinyvirtualtours.com/PTPV ... oTest.html
This one is RC 2 - Two errors..
http://www.destinyvirtualtours.com/PTPV ... llery.html
RC 1 - Two errors..
and
Beta 5 has only one error, the "Viewport argument"
Beta 4 same, only one error.. Not sure if its the media plugin thats in the Tour that accounts for the JS error..
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 8:47 am
Hey Gerald.. This might give you more insight at the right of the screen shots.. I see the same kinds of errors with other members Tours.. So its not my Tours... Seems it cannot find JS files.. The second screen shoot is from the thread "Video Don't Work" viewtopic.php?f=92&t=22156
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Apr 16, 2014 8:47 am
I do not see any error in this one
Destiny wrote:This one V2 - Same two errors...
I do not see any error in this one too
Destiny wrote:This one is RC 2 - Two errors..
No error too
And the fourth link is the same as this one. So I do not see any error too.
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 8:56 am
How strange..
Then it must just be one of those things..
Did you try do this on a Mac with Mavericks and the latest Safari.. Using its web inspector.. ???
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 9:24 am
Really strange.. The Web inspector is rubbish.. I have checked the html template and checked the build html and the folders with the JS, and they all match.. Yet the web inspector does not recognise the full naming of the JS.. This is causing the error.. I clicked on the link it produced and it cannot find the file.. but the web inspector is wrong. That file does not exist in the folders and its not supposed to be there..
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Apr 16, 2014 9:35 am
Destiny wrote:Really strange.. The Web inspector is rubbish.. I have checked the html template and checked the build html and the folders with the JS, and they all match.. Yet the web inspector does not recognise the full naming of the JS.. This is causing the error.. I clicked on the link it produced and it cannot find the file.. but the web inspector is wrong. That file does not exist in the folders and its not supposed to be there..
Destiny, you are right.
Just take a look at the code of the 2 following HTML pages :
and
Look at line "55".
In the first HTML page some includes are lacking.
When you rebuild a tour, are those includes lacking ?
Are you able to tell when they are lacking and when they are not ?
I opened an issue about these lacking libraries. But I wonder how and when they lack.
FORGET THIS POST, I FOUND THE REASON. It is not a bug. The includes are added only if you have some HTML5 plugins.
by klausesser » Wed Apr 16, 2014 10:00 am
bdd wrote:The includes are added only if you have some HTML5 plugins.
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 10:30 am
Thank you Gérald...
At least I am not going crazy.. =D
Likes: 84 posts
Liked in: 186 posts
by benji33 » Wed Apr 16, 2014 11:11 am
Is it your own template with jquery-xxx.js link rather than jquery-xxx.min.js link ?
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 11:17 am
No Benjamin since this issue is present with this Tour....as you can see at this screen shot... Its not my tour... Same error.... same JS file..
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 2:05 pm
... and when I change the name of that JS file and add it to my lib folder.. the error is removed. But there is still one error left.. This first screen shot is from a member recently posted a Tour.. Same issue.. Perhaps none of it matters... Everything seems to work... But... I am not a programer so not sure if it gives rise to other issues...
