video box - don't work on Mobile
tamiro
Likes: 12 posts
by tamiro » Wed Apr 16, 2014 7:29 am
see here
http://www.360vr.tamiror.com/wp-content ... 60-vr.html
it's work fine on PC and Mac
but not in the mobile
why?
the video box is in the white left frame (the bottom frame)
Liked in: 227 posts
Re: video box - don't work on Mobile
by Destiny » Wed Apr 16, 2014 7:52 am
Hi....
Firstly be advised that one of your js files cannot be found..
jquery-2.0.3.js
There are actuarially two errors, one I need to make sure Kolor are apprised of.. Its not your tour, its something in the html template.. An error which is ignored...
With your video, how big is it.?? If its too big it will not load on a device. Even on my Mac its not playing very well at all.. You need to make sure its set for web viewing..
I like the artistic way you have used to showcase your media...
tamiro
Likes: 12 posts
by tamiro » Wed Apr 16, 2014 8:05 am
Hi Destiny
tanx
the video im talkin about it's a You Tube link in the Video Box
you are talking about the video of the first white frame in the tour
that video it's 20 BM
i have tried to use a small MP4 file (4.5 MB) but for some reason it's not work
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Apr 16, 2014 8:13 am
tamiro wrote:see here
why?
I found the video box over the butterfly frame.
I think that it does not work because you set it over an "empty" video spot.
If you set a video in the video spot does it work ?
Or if you set an transparent polygon spot, instead of an empty video spot, does it work ?
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 8:17 am
Hi..
Well the YouTube video should stream in but, how did you add a YouTube to a Movie Polygon.. Did you download the entire movie and save the movie in one of your folders, since you cannot add a YouTube into Polygon..
tamiro
Likes: 12 posts
by tamiro » Wed Apr 16, 2014 8:32 am
yes it's a polygonhot spot that set as a video spot that conect to Web Video box that linked to You Toub
https://www.youtube.com/watch?v=MopeNXDleio
See the atachments
by mediavets » Wed Apr 16, 2014 8:43 am
tamiro wrote:yes it's a polygonhot spot that set as a video spot that conect to Web Video box that linked to You Toub
See the atachments
Despite PTP 2.x allowing you to configure a Video hotpot in that way I don't think it will work.
Why are you using a Video hotspot to invoke a Web video box?
Video hotspots are intended for embedding local video in a scene, you cannot embed web video in a scene.
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Apr 16, 2014 8:50 am
See the atachments
Mediavets is right, video hotspots are intended for embedding local video, like you did in the second video spot of your tour.
For this one you left the "File" field empty in the spot parameter.
tamiro
Likes: 12 posts
by tamiro » Wed Apr 16, 2014 9:09 am
OK
so i have to set a point hot spot that will "call" for the video box?
by mediavets » Wed Apr 16, 2014 9:38 am
tamiro wrote:OK
Yes, or you can use a Simple button plugin if you want a tour-wide button.
Liked in: 227 posts
by Destiny » Wed Apr 16, 2014 10:50 am
... but if your video is sooo big, you might need to consider a player to stream the video in.. But... that cannot be added to a spot.. It can only go into a kolor box.. I have requested as a future feature that it the kolor box can be attached to the actual pano so it moves with the pano.. This would open up so many opportunities. But.. I do not think its possible ... but if it is, we will not see it for a very long time.. :(
