[SOLVED] Image Gallery Action Parameters Limit
pxlvue
by pxlvue » Tue Apr 15, 2014 12:33 am
Looks like the highest index for choosing open on specific image is 100, and not higher.
In this instance I have 140 Images, and need to open on #107.
Josh Latham
Creative Director
www.pxlvue.com
OSX 10.9.2
KPT 2.0.1 64
Likes: 3 posts
Liked in: 215 posts
Re: Image Gallery Action Parameters Limit
by Destiny » Tue Apr 15, 2014 1:20 am
Hi.. Are able to manually add your image number... if not, you might be able to edit it in the XML...
To be honest, this is a huge gallery.. and since there are no thumbs or quick nav yet, it might be a good idea to split the Galleries.. You can have as many Galleries as you like..
by mediavets » Tue Apr 15, 2014 8:16 am
pxlvue wrote:Looks like the highest index for choosing open on specific image is 100, and not higher.
In this instance I have 140 Images, .
Wow - how long does it take to load before the first gallery image is displayed when the tour is online?
Likes: 11 posts
Liked in: 94 posts
by bdd » Tue Apr 15, 2014 9:22 am
We opened an issue about this bug.
But by the way, you can fix it either in the generated code, by specifying the correct index directly in the action call.
Or by copying the gallery plugin, and change the maximum value of the action parameter in the plug_info.xml file.
mediavets wrote:Wow - how long does it take to load before the first gallery image is displayed when the tour is online?
When you open the gallery only 3 images are loaded :
- the one you want to display
- the next image in the list
- the previous image in the list
So the time to display a gallery does not depend on the number of images in the gallery.
by mediavets » Tue Apr 15, 2014 12:38 pm
Has that always been the case or is that new to 2.1 RC1?
Likes: 11 posts
Liked in: 94 posts
by bdd » Tue Apr 15, 2014 12:43 pm
It is not new to 2.1 RC1.
It is the case since a 2.0 beta version, I do not remember which one.
pxlvue
by pxlvue » Tue Apr 15, 2014 4:51 pm
Thanks so much Gérald. Very helpful, I'll update it in the code.
Josh Latham
Creative Director
www.pxlvue.com
OSX 10.9.2
KPT 2.0.1 64
