PTP 2.1 RC Bug Nadir Patch   [SOLVED] - View the solution
Xander Berkenhagen
Likes: 4 posts
Liked in: 8 posts
by Xander Berkenhagen » Tue Apr 15, 2014 12:28 am
Using the mac version.
I can't get any nadir patches anymore.
Likes: 13 posts
Liked in: 115 posts
Re: PTP 2.1 RC Bug Nadir Patch
by bdd » Tue Apr 15, 2014 8:30 am
Xander Berkenhagen wrote:Using the mac version.
We reproduced this bug, and we opened the issue 3419 about it.
shop360
by shop360 » Fri Apr 18, 2014 6:53 pm
any idea when this will be fixed? need to patch nadir for some clients right now..
pretty crucial point considering theres a giant black hole in the middle :P
by mediavets » Fri Apr 18, 2014 7:12 pm
shop360 wrote:any idea when this will be fixed? need to patch nadir for some clients right now..
Would a nadir logo be a workaround?
mmu
by mmu » Tue May 06, 2014 1:15 am
Have similar issue, the nadir property is not available in Panotour Pro V2.0.1. Am running MACOSX 10.6.8.
How do I restore the nadir property?
Panorama properties
by mediavets » Tue May 06, 2014 6:12 am
mmu wrote:Hi,
It is a known bug in Mac version:
viewtopic.php?f=92&t=22140&p=141929#p140628
Consider using a Logo plugin at the nadir as a workaround.
Likes: 13 posts
Liked in: 115 posts
by bdd » Tue May 06, 2014 8:15 am
mediavets wrote:
mmu wrote:Hi,
This issue is fixed in the 2.1 version.
Is your panorama a real full sphere : 360°x180° ?
mmu
by mmu » Tue May 06, 2014 9:54 am
Hi Gerald,
Thanks for your quick reply.
It's essentially a full sphere 360x180, shot using a Gigapan tripod head. Just the black hole at the bottom to patch.
by mediavets » Tue May 06, 2014 10:15 am
mmu wrote:Hi Gerald,
'Essentially?
Either the image has an aspect ratio of 2:1 and a field of view of 360x180 or it doesn't.
If it doesn't the nadir patch option is not available.
mmu
by mmu » Wed May 07, 2014 3:16 am
The image is 29813 x 13852px.
Nadir option was available to me with the same image in Panotour Pro 1.8.
by mediavets » Wed May 07, 2014 6:30 am
mmu wrote:The image is 29813 x 13852px.
I think you are mistaken.
