Autorotate doesn't
andy4nothin
Autorotate doesn't
by andy4nothin » Tue Apr 08, 2014 7:53 pm
Just downloaded 2.01 to create a quick visual for a prospective client and autorotate doesn't start after the specified delay.
Is there some setting that I'm missing?
Once autorotate is turned on, you can click the image to pause and it will restart after the specified time.
I can see waittime and speed are specified in the xml.
Re: Autorotate doesn't
by mediavets » Tue Apr 08, 2014 8:07 pm
andy4nothin wrote:Just downloaded 2.01 to create a quick visual for a prospective client and autorotate doesn't start after the specified delay.
Did you set the Start parameters appropriately?
andy4nothin
by andy4nothin » Tue Apr 08, 2014 8:23 pm
Cheers. Didn't notice those down there!
