Gyroscope enable/disable action - bug?
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Fri Apr 04, 2014 9:46 pm
I suppose that the action "disable gyroscope" and "enable gyroscope" both make the same thing: to toggle between on and off. If I have a button that disables gyroscope, then it enables gyroscope if gyroscope was off before. What I really need is that first it should be checked if gyroscope is already off and then the "disable gyroscope" should do nothing.
Is it correct what I found out or did I just misunderstand something?
ZITRONENWOLF
Liked in: 5 posts
Re: Gyroscope enable/disable action - bug?
by ZITRONENWOLF » Sun Apr 13, 2014 6:00 pm
Now I had a look at the xml-file. It seems correct. There are "enableGyroscope" and "disableGyroscope" commands. But "disableGyroscope" enables Gyroscope if Gyroscope was already disabled.
Is this a bug from krPano?
