more than 20 buttons.
aircamera
by aircamera » Sun Mar 30, 2014 11:58 am
Hi !
I'm working on a tour that has more than 20 buttons in "Style" tab.
When PTP2 creates the tour, buttons >20 are not visible. In "360_skin.xml", all these buttons are named "button" instead of "button20" ; "button21"...
I tried to change names myself, but I can't make them appear.
What shall I do ?
Thank you for your help !
Cyril
Re: more than 20 buttons.
by mediavets » Sun Mar 30, 2014 12:32 pm
aircamera wrote:Hi !
What shall I do ?
Cyril
The button plugins are tour-wide rather than scene/pano-specific.
Does this mean you want to have more than 20 buttons visible over the top of very scene/pano?
What function do all the buttons serve?
aircamera
by aircamera » Sun Mar 30, 2014 12:48 pm
Yes, that's what I need !
To do something like this : http://www.aircamera.fr/visite_virtuell ... e/360.html
jschrader
Liked in: 3 posts
by jschrader » Tue Apr 01, 2014 5:27 pm
I have done something similar with 35 different image hotspots in a panorama, and that works fine.
Probably you would want to try this.
aircamera
by aircamera » Sat Apr 19, 2014 4:20 pm
OK, I understood what's happening...
I created a new project, added 30 buttons, and everything worked well...
But then I saved and I exited project. When I open it again to add one more button, the 31th button is called "button 110" !
If I open .kpt file with notepad++, I can see that new button : <plugin id="button" name="Bouton simple110">
I changed it manually and opened in PTP2 and evething works fine.
There's a big bug here...
