where is add rectangel in panotour 2.0 ????????????!!!!
sikhoonak
by sikhoonak » Wed Mar 26, 2014 4:20 pm
in panotour 1.8 users can add custom hotspot (png,jpg and swf format) by "add rectangel" option
This tool gives the ability to them that can add SWF arow to panoroma.also this option gives rotate 3D platform to hotspot and very useful
i cant find this kind of hotspot in panotour 2.0 !!!
where is it?
Re: where is add rectangel in panotour 2.0 ????????????!!!!
by Annis » Wed Mar 26, 2014 4:42 pm
The rectangle hotspots have been replaced by the Picture and video hotspots.
By default, Picture hotspots don't have an action, but you can change that in the Style tab, in your hotspot styles to use it to navigate instead.
I suggest you check out our FAQ for 1.8 users.
sikhoonak
by sikhoonak » Wed Mar 26, 2014 6:32 pm
thanks ,i added picture hotspot as flash file.i set action for it,but when click on swf hotspot its animate to down and resize to 0px and so hide !!!
i think this problem happend because i set action,and remove action,but steel i have problem.
by mediavets » Wed Mar 26, 2014 6:43 pm
sikhoonak wrote:thanks ,i added picture hotspot as flash file.i set action for it,but when click on swf hotspot its animate to down and resize to 0px and so hide !!!
If you just want to use a custom graphic for a normal (Point) hotspot then you can: of course SWF files can only be displayed on Flash-enabled platforms.
sikhoonak
by sikhoonak » Wed Mar 26, 2014 8:07 pm
i think its a bug!
please add photo hot spot and then add flash file ,when you run panorama and click on hotspot (contain swf file) the hot spot was hidden !
why?
by mediavets » Wed Mar 26, 2014 8:48 pm
sikhoonak wrote:i think its a bug!
why?
What did you want to happen?
sikhoonak
by sikhoonak » Thu Mar 27, 2014 3:59 am
also when you add video file,cant control timing !
Right?
by mediavets » Thu Mar 27, 2014 9:40 am
sikhoonak wrote:also when you add video file,cant control timing !
Right?
What do you mean by 'control timing'
