MAP hotspots miss tooltips
anaka
by anaka » Wed Mar 19, 2014 3:22 pm
on the latest release the map hotspots
no more show the tooltips...
this was an old bug...pleas fix it again
I'm on win7 64bit
Re: MAP hotspots miss tooltips
by mediavets » Wed Mar 19, 2014 4:09 pm
anaka wrote:on the latest release the map hotspots
I'm on win7 64bit
Are you placing Map hotspots automatically via geolocalisation, or using the Hotspot editor?
anaka
by anaka » Wed Mar 19, 2014 4:23 pm
they are hand made
both the panorama hot spots and the icons hot spots
they come from the old file that was perfectly working before to use the latest build...
Likes: 82 posts
Liked in: 183 posts
by benji33 » Fri Mar 21, 2014 11:04 am
PTP version 2.0.1 ?
Tooltip text is not available into interface when you select a spot ?
anaka
by anaka » Mon Mar 31, 2014 11:34 pm
yes 2.0.1
when i pass over with the mouse i get no more tooltips
Likes: 82 posts
Liked in: 183 posts
by benji33 » Tue Apr 08, 2014 1:15 pm
Perhaps the hotspot style has been lost.
Is it possible to visualize your kpt file ?
