fullscreenproblem on iPad   [SOLVED] - View the solution
URS
by URS » Wed Mar 12, 2014 10:18 am
Hi Kolor team,
I also have the problem with the fullscreen function on iPad. The web company integrated the panorama in the clients website.
The fullscreen works perfect on the computer but is not working on the iPad. Could it bee there is the same problem with allowing fullscreen on iFrame ?????
I show you the link where you can find the panoramas I talk about : http://www.pilatus.ch/de/seminare-banke ... ipfelsaal/
I need to know what to tell the web company what they have to take care of !
Thank you very much for a answer . :)
Re: fullscreenproblem on iPad
by benji33 » Wed Mar 12, 2014 4:47 pm
A true fullscreen doesn't exists on iPad.
URS
by URS » Wed Mar 12, 2014 5:02 pm
Hi Ben,
a friend of mine was now testing around and came with this; http://static.nambu.ch/avocado/pilatus360/index.html
It seems possible to make it work, but I don't know how he did it !
Can you explain me way it's not possible to integrate the fullscreen again as standard for the iPad/iPhone as it was by the 1.8 version ?
Thanks,
Urs
Re: fullscreenproblem on iPad  [SOLVED]
by benji33 » Thu Mar 13, 2014 9:06 am
Look after fullscreensupport strings into yourtour_skin.xml file and remove each condition.
For instance :
if (device.fullscreensupport,
      set(layer[theme2btn_openfs ].x, get(theme2button_pos));
      set(layer[theme2btn_closefs].x, get(theme2button_pos));
      inc(theme2button_pos, 36);
change it to :
For instance :
<action name="enterFullScreenChangeEvent" devices="fullscreensupport">set(tour_fullscreen,true);events.dispatch(onenterfullscreen);</action>
change it to :
<action name="enterFullScreenChangeEvent">set(tour_fullscreen,true);events.dispatch(onenterfullscreen);</action>
aircamera
by aircamera » Sat Apr 26, 2014 2:51 pm
Hi !
I'm trying to enable fullscreen on Ipad but didn't get good results yet.
I've deleted all strings where (devices="fullscreensupport") appears, and I can display FS button now ;)
But clicking on the button doesn't work like on your friend's example.
Iframe code is :
<iframe src="http://www.aircamera.fr/visite_virtuelle/golf_les_gets/360.html" width="514" height="385" allowfullscreen="true" mozallowfullscreen="true" webkitallowfullscreen="true"></iframe>
What shall I check ?
Thank you very much for your help !
Cyril
