problems with CDN server and cross domains on Ipad !
URS
by URS » Thu Feb 20, 2014 5:48 pm
Post subject: problems with CDN server and cross domains !!PostPosted: Thu Feb 20, 2014 5:45 pm
Online
the web company who supposed to implement my panoramas came back to me with all kind of problems they have with the implementation of the Panoramas on a CDN server.
Please can you open this links on a a Ipad and tell me way it's not working correctly.
On the Ipad nothing is working !!!! =( ( fatal error: .xml- loading failed !!!!!
Is there something they have to take care specially ?
http://www.pilatus.ch/de/seminare-banke ... ichkeiten/
can somebody help ??????
thank you URS
Likes: 84 posts
Liked in: 186 posts
Re: problems with CDN server and cross domains on Ipad !
by benji33 » Fri Feb 21, 2014 10:35 am
You have only integrate the embedpano method and the panoDIV, all css and js scripts are not loaded in your case, so the HTML5 version can't look after the messages xml file.
In fact it's better in your case to use for the 2 visits :
<iframe src="http://pilatus.webtuning-cdn.ch/panorama/pilatus-vr/sommer/pilatus-vr.html" allowfullscreen></iframe>
and
<iframe src="http://pilatus.webtuning-cdn.ch/panorama/pilatus-vr/winter/kulm.html" allowfullscreen></iframe>
into your <div class="webautor-container">...</div> containers.
Because integration of multiple tours into the same page can be very hard to do due to JS call options. iframe tag usage remove this problem.
URS
by URS » Fri Feb 21, 2014 11:03 am
thank you ! :)
