Panorama Menu visible over video
Tonylujien
by Tonylujien » Tue Feb 18, 2014 4:59 pm
Hi the plugging panorama menu is display above the display point video (when the video is playing)
here is an example
http://www.tonylujien.com/pano/HaarlemKlimmuurvid.html
see the video on the wall (click on the icon)
is there a way to change that ?
Tony
Likes: 84 posts
Liked in: 186 posts
Re: Panorama Menu visible over video
by benji33 » Wed Feb 19, 2014 3:24 pm
At this time some plugin (HTML5 ones : PanoramaMenu, FloorPlan, PanotourMaps, Viewers) are over all other components.
Show/Hide/Toggle actions for each plugins will be done into a 2.X version and will offer the ability to hide menu when video is called.
Tonylujien
by Tonylujien » Thu Feb 20, 2014 10:25 am
benji33 wrote:Hi,
thanks good to know =D
I will use the web plugin video box instead
one more question the PanoramaMenu is not responsive at the moment right ?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Fri Feb 21, 2014 10:17 am
Yes it's right, a task is opened for this point. Avoid big menu for mobile compatibility.
