[SOLVED] PTP2 doesn't remember projection settings.
aircamera
by aircamera » Sat Feb 15, 2014 10:01 pm
Each time I open an existing project with PTP2, it loads panos but with strange projection settings. I have to set again 360x180x0 for each pano each time I open my saved projects...
That's a bit boring when there is over 30 panos in a tour...
Is there anything we could do to fix this little problem ?
Thank you for your help !
Cyril
Re: PTP2 doesn't remember projection settings.
by mediavets » Sat Feb 15, 2014 10:17 pm
aircamera wrote:Each time I open an existing project with PTP2, it loads panos but with strange projection settings. I have to set again 360x180x0 for each pano each time I open my saved projects...
Cyril
May be a silly question but do your pano images have a 2:1 aspect ratio?
aircamera
by aircamera » Sat Feb 15, 2014 10:34 pm
Hi !
Yes they have good ratio 2:1. Some of them are 1pixel offset like this example : 12685x6343.
I just checked, but even if I change for 12686x6343 the problem remains...
by mediavets » Sat Feb 15, 2014 10:37 pm
aircamera wrote:Hi !
When you first add(ed) these pano images to the tour did PTP set the pano FOV as 360x180x0?
I f you were to quickly create a small simple test tour with some of these images do you experience the same problem?
Which version of PT/PTP are you using with which OS?
Was this tour originally created with this same version of PT/PTP?
by benji33 » Mon Feb 17, 2014 2:00 pm
With PTP2 Final version (2.0.0.400) ?
aircamera
by aircamera » Mon Feb 17, 2014 7:10 pm
by benji33 » Tue Feb 18, 2014 9:07 am
Yes issue is found. It was corrected but a recent change re-activate this problem. I've filled a bug report for this point. Thanks for your report.
aircamera
by aircamera » Sat Mar 08, 2014 10:54 pm
Problem is fixed with new update. Thank you !
