Ptp 2.0 - final release
bob1010
Liked in: 3 posts
by bob1010 » Tue Feb 11, 2014 3:02 pm
Hi Benjamin, just want to let you know that the final release has ironed all the glitches with image orientation the on Nokia lumina 520 in mobile mode and all other platforms too - top job, thanks to you and your team for developing such a great piece of software. Keep up the good work.
Cheers,
Rob
jhovilai
Re: Ptp 2.0 - final release
by jhovilai » Tue Feb 11, 2014 8:43 pm
This is my first post here. I had no problem earlier, but now with the final version the hot spots are not working any more with my Nokia 1020 windows phone. I can only see the first panorama and it works fine. With PC it works just fine.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Wed Feb 12, 2014 9:59 am
Hi I report the problem : "hot spots are not working any more with my Nokia 1020 windows phone". Thanks for report.
Seems linked to the panorama player and windows phone OS compatibility.
Does it work if you disable multi-resolution on the Build screen ?
Which is your browser on Windows Phone ? Which version ?
jhovilai
by jhovilai » Wed Feb 12, 2014 10:56 am
The phone os is the Lumia Black version 8.0.10517.150. The hot spots worked on tours generated before the last Ptp 2.0 update. The problem earlier was that my own icons were replaced with the default Ptp icons when browsed on mobile phone, however they worked, but with wrong icons. With PC they worked fine.
I'll test the multiresolution thing later today.
E: Deactivating multiresolution didn't help at all.
jhovilai
by jhovilai » Sat Feb 15, 2014 8:37 am
I don't know what I did, but now I see the hot spots in my Windows Phone as well. It seems the results are dependent on which UI tab the user is when generating the tour.
Also I did find the maps somewhat useless in windows phone, but they're working fine with PC. Any change configuring mobile version differently than workstation version.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Wed Feb 19, 2014 11:17 am
jhovilai wrote:Any change configuring mobile version differently than workstation version.
This is into our feature request list. A tab for each kind of devices with conditionnal plugins.
HansKeesom
by HansKeesom » Wed Feb 19, 2014 11:27 am
Sounds like not an easy thing. My compliments for the compatibity you already have given us!
