Buy discounted Panotour Pro with krpano 1.17 license
Harrylein
by Harrylein » Mon Feb 10, 2014 11:23 am
Hi all,
I asked this question earlier via contact form but got no answer.
I'd like to buy the discounted Panotour Pro 2.0 for 299,- Euros. Since Version 1.17 krpano hasn't got licence files any more but a textcode as licence. In the ordering process of Panotour Pro I'm asked for uploading the two license files - but I just have the text license.
So what do I have to do?
Thanks a lot!
Harry
Likes: 13 posts
Liked in: 115 posts
Re: Buy discounted Panotour Pro with krpano 1.17 license
by bdd » Tue Feb 11, 2014 1:50 pm
Harrylein wrote:Hi all,
Thanks a lot!
Harry
We are working on this issue.
It should be fixed this afternoon (France Time Zone).
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Feb 12, 2014 12:58 pm
bdd wrote:We are working on this issue.
It took more time than we thought to upgrade it, but now our system should allow you to enter the new krpano license instead of the 2 old krpano license files;
Harrylein
by Harrylein » Wed Feb 12, 2014 2:09 pm
Hi Gérald,
thanks for your answer.
I can now enter my license but when i press "submit" nothing happens (just the same site is loaded).
Regards
Stephan
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Feb 12, 2014 3:07 pm
Hi Gérald,
Regards
Stephan
May be you did a mistake when copying the license.
No error message was written, that's why "nothing happens".
We just add an error message when the license is not a valid one.
Can you re-try ?
Harrylein
by Harrylein » Wed Feb 12, 2014 3:18 pm
Thanks for your quick reaction.
Indeed, now there was the error message. It was the correct key, copied out of the mail from krpano.
I think, I found the failure: the key in the mail from krpano is divided in four rows, like:
sdöflasdökjföalfdajfldkfj
alöskfjalsdjfljdlfasldfkjad
pösaflkdjfladkjflakdjflkajdlkf
lkasfjladsjlajfladjflakjfafalfdjlk
If you copy this code it isnt considered as valid. So I copied the code in a texteditor an removed the line breaks. This "cleaned" code worked!
Thanks a lot
Stephan
