Full screen discrepencies
AnnaMaria
by AnnaMaria » Thu Feb 06, 2014 12:23 am
Am about to hand over a tour and feeling less than 100% confident. A couple of things not behaving contratictively. Just one example. The Panorama menu plugin displays as per input but when selecting full screen it changes position? Please see screen grabs.
Any comments appreciated.
Kind regards.
Maria
Full screen.
Not full screen.
Re: Full screen discrepencies
by mediavets » Thu Feb 06, 2014 12:45 am
AnnaMaria wrote:Am about to hand over a tour and feeling less than 100% confident. A couple of things not behaving contratictively. Just one example. The Panorama menu plugin displays as per input but when selecting full screen it changes position? Please see screen grabs.
Kind regards.
Maria
I guess inevitable if there's a fixed vertical offset?
AnnaMaria
by AnnaMaria » Thu Feb 06, 2014 1:30 am
Thanks Mediavets, So what you're saying the parameters you set are not applicable in full screen?
by mediavets » Thu Feb 06, 2014 1:35 am
AnnaMaria wrote:Thanks Mediavets, So what you're saying the parameters you set are not applicable in full screen?
I think what I'm suggesting is that if the vertical offset is say 100 pixels then relative to the pano image it will appear to move up when in fullscreen mode?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Feb 06, 2014 9:41 am
If menu is centered on horizontal axis, on fullscreen and into a window it's placement is the same, but others elements are resized as the line or logo placement etc ...
Seems normal.
In fact you would like that the menu scale change in fullscreen mode to keep it's position as in window mode for instance ?
AnnaMaria
by AnnaMaria » Thu Feb 06, 2014 1:37 pm
Thank you very much for your explanations.
