issues when virtuall tour seen on ipad
viewmaster
by viewmaster » Sat Feb 01, 2014 7:00 pm
When I see my vt on ipad I've noticed these three issues:
1) some of the panoramas don't load fully, there are black areas
2) wherever there is a video then a black screen with a play button appears and it does not disappear when the video plays and
3) the pdf files do not load fully and only the first six pages are visible no matter how many pages the pdf file has
I attach some screenshots, too.
Thank you
Thomas
Re: issues when virtuall tour seen on ipad
by klausesser » Sat Feb 01, 2014 10:08 pm
viewmaster wrote:Hello,
Thank you
Thomas
Hi Thomas!
Missing parts of a pano on iPad/Androids can happen due to a bad connection or the capacity of your device. If there was something really missing on your server you would get an error-message. (at least that is with PTP 1.8 and KRPano)
The missing video might have other reasons - i suggest to check all the settings.
best and good luck, Klaus
Likes: 80 posts
Liked in: 182 posts
by benji33 » Mon Feb 03, 2014 8:46 am
Do you have an url for test ?
You're using Mono or Multi resolution panoramas (see build screen)
For Video play button I'll have a look.
It's a hotspot with action display video ?
For PDF, into the advanced options of the PDF viewer, you can set the max width height of the display part. So If your PDF navigation is vertical update the value to set a high height value to be able to view all pages on devices.
viewmaster
by viewmaster » Tue Feb 04, 2014 9:24 am
Klaus, thank you for your reply.
Benjamin, I'll check the settings you are suggesting and I will post my reply soon.
Thank you both!
Thomas
aircamera
by aircamera » Fri Feb 07, 2014 5:19 pm
I have same problem here with PTPv2.0.0 64bit multiresolution :
http://www.aircamera.fr/visite_virtuelle/ESF_Morzine/360.html
It works fine on Samsung S3 but not on Ipads...
Likes: 80 posts
Liked in: 182 posts
by benji33 » Mon Feb 10, 2014 9:36 am
aircamera wrote:It works fine on Samsung S3 but not on Ipads...
No issue on IPad 3 test. What is the problem ?
aircamera
by aircamera » Mon Feb 10, 2014 4:16 pm
Display is not working... Look at this : http://www.youtube.com/watch?v=kHZ4vuAVKM8&feature=youtu.be
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Feb 11, 2014 9:21 am
I've tested on iPad2 on iOS6 without your issues. Do you have clean cache of the Safari browser ?
aircamera
by aircamera » Tue Feb 11, 2014 9:14 pm
Thank you Benjamin for this test.
Yes, I did clean cash...
Every tours that I built since v2 RC shows same troubles.
The fact is that my Ipad doesn't ask me to proceed to an update. So for people who bought same device than me, this tour does not work ?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Feb 12, 2014 9:54 am
With cleaned cache it works ?
If the tour has been visualized and is into the cache the new version can be display with issues, yes it's possible.
aircamera
by aircamera » Wed Feb 12, 2014 6:08 pm
No, even if I clean cash, the problem remains...
And every tours that I built since v2 RC shows same troubles.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Feb 13, 2014 9:15 am
First test :
If you add this code into your main xml file what happens ?
<memory maxmem="20"  devices="iOS" />
So memory max used will be 20MB rather than the default 40MB.
Second test :
If you add this code multiresthreshold="-0.5" into the main xml file of your tour into all the <image> tags what happens ?
<image ... multiresthreshold="-0.5" ...>...</image>
This will load only one level into multi-res images.
aircamera
by aircamera » Thu Feb 13, 2014 1:45 pm
Thank you once again for this test !
So <memory maxmem="20" devices="iOS" /> seems not to change anything.
And <image type="CUBE" multires="true" baseindex="0" multiresthreshold="-0.5" tilesize="512"> doesn't change anything either...
When I try <image type="CUBE" multires="false" baseindex="0" tilesize="512">, The picture changes a little bit :
