little planet effect appears with black corner
viewmaster
by viewmaster » Sun Jan 26, 2014 10:38 am
When I use the little planet effect in ptp 2.0 it appears with black corners and the movement is not as normal (jagged) as it was in ptp 1.8. The black corners appear in a 22in screen. In smaller screens there are no black corners but the problem with the movement is the same.
You can see an example in this link: http://thomas360.dotsyntax.gr/little_pl ... error.html
Thomas
Likes: 41 posts
Liked in: 145 posts
Re: little planet effect appears with black corner
by benji33 » Mon Jan 27, 2014 9:03 am
Ok reproduced on the flash player on your visit.
I'll add a report for this problem.
Is it possible to send me informations about your file : width and height in pixels ?
Or better, is it possible to send us your equirectangular, and your project file ?
viewmaster
by viewmaster » Mon Jan 27, 2014 5:22 pm
The width is: 8000px
The height is: 4000px
Yes, I can send you the file. Where should I send it to?
Thomas
Likes: 41 posts
Liked in: 145 posts
by benji33 » Tue Jan 28, 2014 9:20 am
On contact@kolor.com (for benjamin or gerald). Thanks
fotojehle
by fotojehle » Tue Jan 28, 2014 10:36 am
I have the same issue, I think since krpano 1.17
http://360virtualtour.ch/panos/museumku ... anbau.html 7902 x 3951
http://360virtualtour.ch/panos/panopratteln/pratt.html 7804 x 3902
at the begin of Little planet intro you see the black corners
Thanks Felix
viewmaster
by viewmaster » Thu Jan 30, 2014 9:18 am
I've tried a couple of things and I discovered that when I don't select the multiresolution option in output the problems with the black corners disappear.
http://thomas360.dotsyntax.gr/little_pl ... rror2.html
Likes: 41 posts
Liked in: 145 posts
by benji33 » Thu Jan 30, 2014 2:07 pm
Next release doesn't use same little planet parameters and it seems working. So problem is probably due to the limitview="lookat" value of the view during littleplanet effect into your RC1 build.
fotojehle
by fotojehle » Thu Jan 30, 2014 3:55 pm
It's also in RC2!
Felix
Likes: 41 posts
Liked in: 145 posts
by benji33 » Thu Jan 30, 2014 4:57 pm
Yes this patch is post RC2 and will be available into next release.
viewmaster
by viewmaster » Sun Feb 16, 2014 6:05 pm
Hi Benjamin,
The little planet effect issues are solved with the new version V2.0.0
Thomas
