How to View Your PTP V2 Tours Locally, DVD or USB FlashDrive
by Destiny » Wed Jan 22, 2014 4:04 am
Hi...
The brilliance of Klaus Reinfeld krpano really shines through here...
For anyone wanting to view their PTP V2 Tours Locally, or burn them to DVD or even copy to a USB Flash Drive to showcase to clients, this is now possible using the new krpano Testing Server....
This works for both Mac and Windows.. You can download the files from here: http://krpano.com/tools/ktestingserver/#top
I suggest you extract both the Mac and Windows Testing Servers from the krpano web site. Then you can burn to DVD or copy to USB Flash Drive; Both Testing Servers, together with your Tour/s...
Since the Testing Sever is in the same File structure as your Tour/s, there is no need for clients to struggle in finding files and folders.. They just open the Mac or Windows Testing Server, where the html files will be available to them..
Re: How to View Your PTP V2 Tours Locally, DVD or USB FlashD
by benji33 » Thu Jan 23, 2014 9:58 am
Thanks for information.
by Destiny » Wed Jan 29, 2014 1:26 pm
I am guessing that some that need to use this feature have not read it.. I have very successfully used the krpano Testing Server on a USB Flash Drive and also burnt a Tour to DVD.. The Tour works ANYWHERE.. The only thing that needs to be considered are plugin features like Google and Bing Maps.. Its not possible to hose the entire server content of these features on a single USB or DVD or any large YouTube video or remote websites linked to a Tour.. Therefore, for those features that require an internet connection there is nothing that can be done about that.. However, if consideration is taken when designing a Tour, it would be necessary to omit any feature that requires web hosted media content, and then a Tour works quite well on a USB and very well on a DVD.. It is advised to load Tours on a good quality High Speed USB Flash Drive... The bigger the Tour the bigger the USB drive will have to be..
All the user/s have to do is click on the KRPANO icon for Window or Mac and then press the link to open the folder.. A green arrow button will be available.. In many cases the Tour works quicker since there is nothing to download... To be honest, I think it might even be possible to view a Tour on a TV.. Some TVs can accept keyboards and a mouse... That would be an interesting test... =D
tamiro
Likes: 12 posts
by tamiro » Wed Jan 29, 2014 2:34 pm
do i need a KRpano license for that?
i have PTP2 license
by mediavets » Wed Jan 29, 2014 2:40 pm
tamiro wrote:do i need a KRpano license for that?
i have PTP2 license
No, no need to purchase anything else, just export your krpano license(s) from PTP 2; Help/Licenses:
didi.lotze
by didi.lotze » Fri May 02, 2014 1:57 am
Hi
I tried to follow the instructions and when I want to open , I got a license error!
Cheers Didi
Likes: 14 posts
by bdd » Fri May 02, 2014 8:27 am
didi.lotze wrote:Hi
Cheers Didi
Did you fill the "Restricted Domains" field ?
If yes, did you add "localhost" as a valid domain ?
didi.lotze
by didi.lotze » Sat May 03, 2014 12:32 am
Ah, have to write it as "localhost"!
Will try!
Didi
didi.lotze
by didi.lotze » Sat May 03, 2014 2:14 am
Gerald,
yes I use the restricted domain and then I tried with "localhost" or "http://192.168.0.103:8090/
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Tue Dec 02, 2014 6:29 pm
Thanks for this information. Everything worked perfectly in 1.8 Feel like it really wasn't worth updating!
Is the server loaded on the computer before a disk/usb drive is inserted or can it be installed to run on a disk? Getting people to understand how to insert a disk can be challenging enough! It needs to be streamlined and having to tell people to download something and set it up first is a major problem. They may not be able to install software or they barely know how to turn a computer on. This isn't a one off for me, the majority of my clients are like this.
I opened the testing server on the hard drive and it just crashes...
by mediavets » Tue Dec 02, 2014 6:54 pm
itsrichphoto wrote:Thanks for this information. Everything worked perfectly in 1.8 Feel like it really wasn't worth updating!
Take a look at the Panotour Viewer which is designed for viewing tours offline:
http://www.autopano.net/wiki-en/action/ ... umentation
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Tue Dec 02, 2014 8:15 pm
thanks mediavets!
I understood that ptv was a standalone software. I therefore hadn't bothered to test it as I didn't understand the purpose other than for mobile devices. It is annoying that it is less streamlined....
I may just redo the last piece in 1.8 though. less problems, less people getting annoyed, less people calling for help and less people saying they won't work with me because they don't know how it works...
Eddie
by Eddie » Wed Dec 03, 2014 4:24 am
Is there any way to test a tour made for smartphones? Test the inferfaz!
Eddie
by benji33 » Wed Dec 03, 2014 10:00 am
With the Developer Interface of Chrome 39.
https://developer.chrome.com/devtools/docs/device-mode
