Question: Compatibility RC1 and RC2 projects
John360
by John360 » Thu Jan 16, 2014 6:08 pm
Hi.
Just wondered if there are any compability problems with RC1 and RC2 for buildt projects. May it be possible to keep tiles from RC1 and just generate the new xml and js files, or is it advised to do full new builds?
John
Re: Question: Compatibility RC1 and RC2 projects
by mediavets » Thu Jan 16, 2014 6:14 pm
John360 wrote:Hi.
John
I don't know if it's necessary but I would always advise a full new 'clean' build into a new folder.
John360
by John360 » Thu Jan 16, 2014 8:03 pm
Just wondering if its necessary with 100K files re-upload on a live project.
by benji33 » Fri Jan 17, 2014 9:40 am
The Panotour ftp program is very simple and keep informations into the same session. on new session, informations are lost and all files are uploaded again.
Prefer an external FTP program.
To avoid rebuild all tiles, save your project once all tiles has been generated. The tiles informations will be stored into kpt file and no longer need to be rebuild normally.
jschrader
Liked in: 3 posts
by jschrader » Fri Jan 17, 2014 2:12 pm
The word "normally" makes me very suspicious here.
Also it seems that with RC2 there is an issue in hotspot linking and especially with website boxes which I widely used in my recent project.
As it seems it is not safe to update to RC2 which is a real pity (but luckily I didn't).
With RCs that should not happen.
by mediavets » Fri Jan 17, 2014 2:29 pm
jschrader wrote:The word "normally" makes me very suspicious here.
I have no problem doing that with RC2 on Windows 7 64-bit
by benji33 » Fri Jan 17, 2014 4:02 pm
Are you on MacOSX Maverick ? Have you tested hotspot link with website boxes ?
This bug only happens for Destiny at this time and has not been reproduced.
For normally, you're right it's my own error because i've not personnally tested this step on all computer OS.
John360
by John360 » Fri Jan 17, 2014 8:53 pm
Thanks. Thats important information. Usually I save I edit, save, edit, save, build.
by Destiny » Sat Jan 18, 2014 1:52 am
My issue only happened due to me using my own customised html template.. Since that was discovered, its all been good.. No other issues with moving up from RC1 to RC2.. If however you too are using a custom html template and you experience issues, it would be advisable to test the default templets first.. It might be a matter of editing or rebuilding your own custom templates since this new build.. New code here was written which stuff my template up.. viewtopic.php?f=3&t=21161#p135312
Unfortunately, in my case this code did not fix my issue. I still cannot get a Website Box or other plugins to trigger from a hotspot using my html template even after adding this code.. :rolleyes:
benji33 wrote:Are you on MacOSX Maverick ? Have you tested hotspot link with website boxes ?
jschrader
Liked in: 3 posts
by jschrader » Sat Jan 18, 2014 6:33 pm
Yes, I am.
by Destiny » Sat Jan 18, 2014 10:58 pm
Just for info.. Read the 3rd paragraph up from bottom here... http://www.autopano.net/wiki-en/action/ ... mputer_.3F
jschrader
Liked in: 3 posts
by jschrader » Sun Jan 19, 2014 6:43 am
Thanks. I have no problems at all.
But that's because I'm still using RC1 :rolleyes:
I yet don't trust RC2 and will not test or even install it until it is considered to be safe with existing projects.
