PT 2.0 RC1 Win - Flat build as cylinder
John360
by John360 » Wed Jan 15, 2014 3:38 am
Im building a tour with multires spherical and flat images. Does not work as HTML5. Looking at the xml I find that its not flat, its cylindrical. Is it supposed to?
<image type="CYLINDER" hfov="1" vfov="0.75" voffset="0" multires="true" baseindex="0" tilesize="512">
Re: PT 2.0 RC1 Win - Flat build as cylinder
by Destiny » Wed Jan 15, 2014 3:44 am
Hey.. Did you choose this option....?
John360
by John360 » Wed Jan 15, 2014 4:03 am
Yes, but its the cylinder button :)
Checked the demos at Krpano and they are cylinder as well.
by mediavets » Wed Jan 15, 2014 9:27 am
John360 wrote:Im building a tour with multires spherical and flat images. Does not work as HTML5. Looking at the xml I find that its not flat, its cylindrical. Is it supposed to?
HTML5 multi-res. on mobiles currently only works if the pano image has a pano FOV of 360x180.
by benji33 » Wed Jan 15, 2014 9:51 am
Flat images are rendered into cylinder with a hfov of 1°.
You can try with the RC2 release which will be available today which should correct the cubical, cylinder, shere xml references for flash, html5 and devices.
John360
by John360 » Wed Jan 15, 2014 11:44 am
Yes, I figured it out, that it was the krpano solution itself. Actually Im bughunting a 100 360 project with two planar images as well. It does not render as HTML5, and looking for errors.
So this one is not a bug.
by benji33 » Wed Jan 15, 2014 11:51 am
If it happens after the install of RC2 (probably available this afternoon) post infos here.
