Adding multiple hotspots to flat projection --> Freeze
John360
by John360 » Fri Jan 10, 2014 8:08 pm
When adding multiple hotspots to an image as flat projection the software freezes and will not respond again. It does not happen if the projection is not flat. I suspect the bug is connected to the UI rendering in the preview.
( Edited after bug testing )
John360
Re: Adding multiple hotspots to flat projection --> Freeze
by John360 » Fri Jan 10, 2014 9:35 pm
Seems like using normal projection when setting hotspots and changing to flat before rendering might be a workaround. Huge memory use when adding lots of hotspot in a project with only a dummy file.
John360
by John360 » Sat Jan 11, 2014 2:04 am
Window freezing and memory status.
Likes: 14 posts
by bdd » Mon Jan 13, 2014 9:41 am
John360 wrote:Window freezing and memory status.
Does the window freeze if you reduce the amount of memory dedicated for Panotour in the Preferences window (menu Edit/Preferences) ?
http://www.autopano.net/wiki-en/action/view/Panotour_Pro_2_-_Preferences
John360
by John360 » Mon Jan 13, 2014 6:24 pm
I have not tried Gerald. Will try when I have some time.
