Errors PTP
Bogdan
Errors PTP
by Bogdan » Thu Jan 09, 2014 8:51 am
I have some technicals problems with PanoTour Pro. I had several errors during my project and the software needed to close, loosing what i have done.
What's the problem? I need this software to work properly until the end of the month. If not, i will looking for other similar softwares to buy.
Likes: 3 posts
Liked in: 225 posts
Re: Errors PTP
by Destiny » Thu Jan 09, 2014 9:43 am
Hi..
How much RAM does your PC have and what are the other specs.....
The requirements you will find here.. http://www.autopano.net/wiki-en/action/ ... quirements
Bogdan
Re: Errors PTP
by Bogdan » Thu Jan 09, 2014 9:52 am
It has 4 GB RAM
i5 - 2320 CPU@3GHz
Re: Errors PTP
by mediavets » Thu Jan 09, 2014 10:13 am
Bogdan wrote:I have some technicals problems with PanoTour Pro. I had several errors during my project and the software needed to close, loosing what i have done.
Are you running a 32-bit version of Windows 7 and the 32-bit version of PTP RC1?
Are you using a laptop?
Can your PC run a 64-bit version of Windows and support more RAM?
What other programs do you have running as well as PTP when the errors arise and the crashes occur?
This may also be relevant:
viewtopic.php?f=92&t=21031&p=134392#p134392
