Possibility of creating more points Start In The Same tour?
snoopcity
by snoopcity » Wed Jan 08, 2014 4:01 pm
I'm doing a project 100 "pano", connected to each other and the tour starts at the "Pano 1", but I need to create 10 pano start inside, how do I do this without having to save and upload to the internet 10 identical projects . I want to load the same project (600 mb) with 10 points associated with 10 different start pages htm different.
I have to edit the xml file, or is there a solution in Panotour 2.0?
Could you explain how to do?
Likes: 13 posts
Liked in: 115 posts
Re: creare più punti di inizio nello stesso tour?
by bdd » Wed Jan 08, 2014 4:19 pm
snoopcity wrote:I'm doing a project 100 "pano", connected to each other and the tour starts at the "Pano 1", but I need to create 10 pano start inside, how do I do this without having to save and upload to the internet 10 identical projects . I want to load the same project (600 mb) with 10 points associated with 10 different start pages htm different.
there is a solution.
You can use "deep links" into the tour.
if your tour is hosted there : www.mywebsite.com/mytour/myfile.html
then you can access any panorama like this :
www.mywebsite.com/mytour/myfile.html?s=a_pano_id
To find the ID of a panorama just look in the panorama property sheet :
http://www.autopano.net/wiki-en/action/view/Panotour_Pro_2_-_Tour_-_Picture/panorama_properties#NAME
snoopcity
by snoopcity » Wed Jan 08, 2014 4:37 pm
grazie bbd, ma non funziona,
the site is this: http://www.snoopcity.it/1/1.html,
this changed and the link with the "pano": http://www.snoopcity.it/1/1.html?s=a_pano_10,
The tour begins with the "pano9", the "3 pano" are: "pano9" "pano10" and "pano11"
gives me the following error: "ERROR: loadscene () - scene "a_pamo_10" not found"
try it yourself
snoopcity
Re: Possibility of creating more points Start In The Same to
by snoopcity » Wed Jan 08, 2014 5:42 pm
Ok, thanks I solved it was: http://www.snoopcity.it/1/1.html?s=pano10
thank you very much
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Jan 08, 2014 5:43 pm
snoopcity wrote:grazie bbd, ma non funziona,
try it yourself
Here are the true links :
http://www.snoopcity.it/1/1.html?s=pano9
http://www.snoopcity.it/1/1.html?s=pano11
snoopcity
by snoopcity » Wed Jan 08, 2014 5:48 pm
Thank you very much bdd
snoopcity
by snoopcity » Wed Jan 08, 2014 5:52 pm
BBD hello, could you also answer this question: viewtopic.php?f=91&t=21047
I would be very grateful
by mediavets » Wed Jan 08, 2014 6:21 pm
snoopcity wrote:BBD hello, could you also answer this question: viewtopic.php?f=91&t=21047
It's the same answer as before isn't it?
viewtopic.php?f=92&t=21044&p=134353#p134337
