RC1 - Panorama menu and Floorplan interactions...
by mediavets » Mon Jan 06, 2014 1:32 pm
If you have a single level floorplan with floorplans for Groups, and a Panorama menu which just shows just groups - with no submenu for panoramas within the group - then when you select a group in the Panorama menu the Floorplan changes to match the selected group - screenshot 1.
But if you also have a submenu for panoramas then the Floorplan doesn't change to match the selected group until you select a Panorama from the submenu - screenshot 2.
Likes: 60 posts
Liked in: 169 posts
Re: RC1 - Panorama menu and Floorplan interactions...
by benji33 » Tue Jan 07, 2014 9:14 am
Do you have a sample online ? Thanks
When you're over or click on the group ? Submenu appears and group doesn't change ?
If yes it's not an issue, Submenu is displayed but no action is sended for selected group until the select of an item into the submenu.
