Some buttons are not showed in iDevices version ...
Adolfo_360vista
by Adolfo_360vista » Fri Jan 03, 2014 10:55 pm
Hi everyone !
here my bug or incompetence ;-) ... I´m start learning to use the last PTP 2.0 RC (a purchased and registered version). Notice that I have not good skills coding, only the basics to understand the xml lines and tags.
It´s essential for me that the mobile/tablet version works fine and my surprise is that some buttons of the control menu disappears on this version. At desktop version is everything OK but on mobile/tablet only three or four buttons are showed.
See attached imgs.
I tested with a lot of kind of menus, I tried to modify the skin XML ... but like I said ... I´m very bad coding !. I tested too uploading to my FTP server and ... no news from lost buttons ;-) !!!
Desktop version
iDevices version
Captura de pantalla 2014-01-03 a la(s) 22.22.43.png (48.33 KiB) Viewed 537 times
Re: Some buttons are not showed in iDevices version ...
by mediavets » Fri Jan 03, 2014 11:11 pm
Adolfo_360vista wrote:It´s essential for me that the mobile/tablet version works fine and my surprise is that some buttons of the control menu disappears on this version. At desktop version is everything OK but on mobile/tablet only three or four buttons are showed.
That's intentional - iDevices have a multitouch user interface which makes the other buttons redundant, and some functions are not supported, so they are automatically removed when a tour is viewed using an iDevice.
Adolfo_360vista
by Adolfo_360vista » Sat Jan 04, 2014 1:02 am
Thank you very much Mediavet for your quick reply ... I understand now !... I thought that was a little bug but now I think is a great responsive solution.
Thank you once again !
Adolfo Rancaño
http://www.360vista.es
