Have been working on a project for a client which was working fine until yesterday. Now everytime I hit 'Build' the program judders then crashes. I'm not sure whats happened or what data to give to help analyse the problem. I've added some screen grabs. Also I've tested a tour with a single panorama and the build worked without crashing. Is there issues with multiple 360's points or multiple galleries that has this effect? or maybe something has corrupted? please let me know any thoughts you may have
Have gone through all the plugins I'm using and found that its the Floor Plan that is causing the crash. I'm using the most current release of the program and running on the latest update of OSX Mavericks. I've tried various combinations on the actual plugin to see if its something such as the animation option that is causing the crash, so far no luck
Only if it was part of an update when you go to help> check for updates It says i've got the most updated version. If i've missed something please hit me up with a URL as it would be much appreciated
