RC1 tours are crashing with Ipad (safari)
moeava
by moeava » Thu Jan 02, 2014 4:40 am
I did a project involving multiple panoramas with the latest RC1:
www.ateadata.co.nz/tect360
The problem is that it keeps crashing on Ipad when using safari. I didn't try on an Iphone, but I guess it should be the same issue.
I did try on a macbook with firefox and safari, and it works well.
The tour has been done under Win7 64bits.
Likes: 13 posts
Liked in: 118 posts
Re: RC1 tours are crashing with Ipad (safari)
by bdd » Thu Jan 02, 2014 9:41 am
moeava wrote:Hi,
http://www.ateadata.co.nz/tect360
I just did a check with Safari on our iPads, and your tour is not crashing.
When does the tour crash on your side? When loading a new panorama, opening the map, etc...?
moeava
by moeava » Thu Jan 02, 2014 10:19 pm
Thank you for your reply.
The tour crashes randomly, it could be after a few seconds or after loading one or two panoramas. There is no specific action that makes it crash.
Since you are telling me that it works fine on your Ipad, I think the problem could be related to my device.
It happens that its hard drive is almost full. Would it be the reason? Does Ipad need to store some temporary data on the hard drive to properly display the tour?
