Virtual Tour Opens TOO SLOW
osamaaf
Liked in: 5 posts
by osamaaf » Tue Dec 31, 2013 9:35 am
I have a virtual tour of a museum on our website which contains 28 panoramas and 667 spots including image spots. When I open it using the following link, it opens too slow. I found that an xml file in the data folder is about 2MB.
My clients are complaining about loading speed. How can we have it load fatser?
Re: Virtual Tour Opens TOO SLOW
by mediavets » Tue Dec 31, 2013 9:59 am
osamaaf wrote:I have a virtual tour of a museum on our website which contains 28 panoramas and 667 spots including image spots. When I open it using the following link, it opens too slow. I found that an xml file in the data folder is about 2MB.
http://www.360folio.com/portfolio/virtual-tours/lyallpur-museum-faislabad-pakistan
Viewing the tour with Firefox on Windows XP/32 via a relatively low bandwidth (about 1.5-2Mbps at best) ADSL Net connection here in the UK I get to see the first panorama in about 40 seconds.
What sort of Net connection bandwidth does your client and typical/target audience have?
What sort of viewing performance do they experience and describe as 'too slow'?
karolski_tomasz
by karolski_tomasz » Tue Dec 31, 2013 10:16 am
I have the same problem with my project 316 pano and 1050 spots, load too slow.
http://spacer.gizycko.pl
by mediavets » Tue Dec 31, 2013 10:24 am
karolski_tomasz wrote:I have the same problem with my project 316 pano and 1050 spots, load too slow.
What kind of performance do you expect or hope for?
I get to see the Splash screen in 30 seconds.
Viewing the tour with Firefox on Windows XP/32 via a relatively low bandwidth (about 1.5-2Mbps at best) ADSL Net connection here in the UK.
karolski_tomasz
by karolski_tomasz » Tue Dec 31, 2013 10:29 am
I do not know, I would expect maybe a progress bar that runs before the splash screen or the distribution of basic xml file (index.xml) into several smaller maybe.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Tue Dec 31, 2013 10:44 am
Yes 8 sec before the splash screen and 20 seconds for full loading.
For the loader, it's difficult, because the XML file of your tour is 2 Mo ... and it's the black screen.
I have work on an HTML5 slashscreen which can be displayed before the load of XML.
But many tests must be done before apply it on the product.
karolski_tomasz
by karolski_tomasz » Tue Dec 31, 2013 10:49 am
benji33 wrote:Yes 8 sec before the splash screen and 20 seconds for full loading.
These 20 seconds after the splash appears not a problem, the problem is just the black screen which depends also on your own computer that displays the tour.
osamaaf
Liked in: 5 posts
by osamaaf » Tue Dec 31, 2013 11:11 am
I have 4Mbps connection and my experience is that I see the black screen for a long time. A loader during this blank black screen can be helpful for clients to tell them the tour is loading and that their own connection is slow. This way they wont complain to me. Please advise.
I also have the xml encrypted. Does this increases the file size? Or at least affects the loading time?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Jan 02, 2014 10:03 am
osamaaf wrote:I also have the xml encrypted. Does this increases the file size? Or at least affects the loading time?
Normally, no changes for the loading time.
karolski_tomasz
by karolski_tomasz » Thu Jan 09, 2014 9:26 am
and will be at all the possibility of loading virtual tour faster? Last I checked generated in krpano tour and there I still had 400 panoramas, and krpano doing a separate xml file for each panorama tour is loaded immediately.
Landroval likes this post.
Landroval
by Landroval » Mon Oct 26, 2015 9:31 pm
So what? Have the same problem: more than 1000 panoramas, xml is over 6Mb, loading time 16 seconds. What a hell?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Wed Oct 28, 2015 10:06 am
In the actual way Panotour can't split the main xml file.
Perhaps the split of the Project into many others with deep linking to merge them on some spots for instance ?
