Radar bug in RC1?
villarosen
Radar bug in RC1?
by villarosen » Mon Dec 30, 2013 6:58 pm
Hi Kolor
Something is wrong with the radar in RC1.
1. If i go from pano1 to pano2 or pano3 - via Group and then activate floorplan the radar hanging on both.
2. If i go from pano1 to pano2 via hotspot same problem
2. If i in pano1 choose to go direct to floorplan and then choose pano2, NO problems!!
And no, Pano1 and Pano2 are not the same, and i have try to delete pano1, save, rebuild all, save and close RC1. I have tried making a new project, with only 2 panos and a floorplan, the problem is still there on every browser, explorer,chrome,safari..
And by the way, the panorama menu (groups in top) disappears in fullscreen on Explorer 9 !
regards
lLon
Likes: 80 posts
Liked in: 182 posts
Re: Radar bug in RC1?
by benji33 » Tue Dec 31, 2013 9:07 am
With FloorPlan patch ? http://www.kolor.com/forum/viewtopic.php?f=92&t=20883
Do you have an online url for tests ?
For IE9 and lower, fullscreen can't display HTML5 plugins, because IE9 never use the HTML5 fullscreen api. It's a known problem which can't be resolved.
by mediavets » Tue Dec 31, 2013 9:11 am
benji33 wrote:For IE9 and lower, fullscreen can't display HTML5 plugins, because IE9 never use the HTML5 fullscreen api. It's a known problem which can't be resolved.
In your (Kolor's) exploration of responsive designs for plugins perhaps you could consider automatically removing the fullscreen button from control bars when a tour is viewed with IE9 or lower?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Dec 31, 2013 9:19 am
Only when the majority of plugins will be displayed in HTML5 version.
by mediavets » Tue Dec 31, 2013 9:35 am
benji33 wrote:Only when the majority of plugins will be displayed in HTML5 version.
I don't understand...
If ANY HTML5 plugin will fail to perform corrrectly when a tour is viewed fullscreen with IE9 or less, then surely it would be sensible to disable the fullscreen option when a tour is viewed with IE9 or less.
You already automatically remove buttons from control bars for some mobile patform.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Dec 31, 2013 10:38 am
Yes but some others plugins are correctly displayed and some persons want the fullscreen. So it's the actual choice which I know is not the good one in some cases.
villarosen
by villarosen » Tue Dec 31, 2013 10:41 am
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Dec 31, 2013 10:52 am
Ok reproduced, thanks. I open the issue.
