Generated by Panatour
George Randy Bass
by George Randy Bass » Fri Dec 27, 2013 11:06 pm
Created my first tour with 2.0 Awesome!
http://midatlantic360.com/wp-content/up ... udios.html
When sharing, how do I remove "Virtual tour generated by Panotour"?
Liked in: 227 posts
Re: Generated by Panatour
by Destiny » Fri Dec 27, 2013 11:27 pm
Hi..
If you mean in your Head Title
<html>
<head>
<meta charset="utf-8" />
<title>RLS : Virtual tour generated by Panotour</title>
The go to view source, you will see the html code, copy it and past into a Plain Text Editor.. Edit your Title and save as the same name.. Now replace the new html with your old one.. Done...
For anything else, you need to buy the Branding Free Licence..
George Randy Bass
by George Randy Bass » Fri Dec 27, 2013 11:45 pm
Thank you for the prompt reply!
"The go to view source" What do you mean?
Randy
Liked in: 227 posts
by Destiny » Sat Dec 28, 2013 12:12 am
"View" - "View Source", in the top of your browser window.. Unless you are using a Mac with Mavericks.. In that case its under Develop...
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Dec 30, 2013 9:46 am
HTML file can be edited to remove and change all texts and html blocks.
Andrew Lyons
by Andrew Lyons » Thu Jan 02, 2014 1:16 pm
Just open the "index" file in notepad, before you upload the tour to your server, and edit the required text in the header.
I've just looked at at your tour, and you've certainly put some effort in there.
It did load a little slowly, which might be because there's an awful lot going on.
Have you ever thought about adding a nadir patch to the tripod legs?
by mediavets » Thu Jan 02, 2014 1:43 pm
George Randy Bass wrote:Created my first tour with 2.0 Awesome!
Viewing you tour with Firefox 26.0 on Windows 7 64-bit.
I've noticed that there appear to be gaps in the PDF bios - here's an example:
George Randy Bass
by George Randy Bass » Thu Jan 02, 2014 3:58 pm
Thank you for the comments!
Below are links to an updated Robert Lange Studios tour and a new tour featuring galleries in Charleston, SC.
http://midatlantic360.com/wp-content/up ... eries.html
How is load time? How can I improve load? Do i need to? jpg quality is set at 8. Will changing this setting effect speed?
Randy
by klausesser » Thu Jan 02, 2014 5:37 pm
My personal opinion from an aesthetical point of view: much too much icons, pictures and other items in the window.
Information is Vital, yes. But it´s also important to find ways to "wrap" information more elegantly i mean.
George Randy Bass
by George Randy Bass » Thu Jan 02, 2014 6:54 pm
I agree Klaus. Attempting to show as many options as available.
UK Pano
by UK Pano » Fri Jan 03, 2014 10:20 am
Interesting gallery
The opening pano has the below on the floor which lets it down. Would not take much to clone out or mask these shadows.
Same applies to the nadir's of the other tours - would no take much to clone/mask out the tripod head or restrict the downward view given there is not a nadir cap in place.
Does the tour benefit from the opening tour in the street and then a second tour 10ft closer at the front door?
The interface is to cluttered. Personally I'm not clear on why the static images are present on the left when you also have an equivalent tour present.
Drop the static shots or put them as a hotspot with the tour if they add benefit and make the horizonatal pano tours on a pull out tab to de-clutter the viewing interface.
Liked in: 227 posts
by Destiny » Fri Jan 03, 2014 10:26 am
Hi..
Do you have the pano to share.. I will explain how to remove that shadow.. The clone tool is a silly tool to use.. I can cause blurring and a fake look... I made up a droplet to clear more of the nadir which works well for my needs..
Use this.. https://www.wetransfer.com/# and send to dps@westnet.com.au
Liked in: 227 posts
by Destiny » Fri Jan 03, 2014 6:37 pm
On its way back to you.... ;)
PS.. Just realised that your ratio was not 2:1, your Zenith was out... Just fixed it for you.. You need to work on your NNP, your stitching is way off.. You can see that in the roof with the huge curve... You now have a FOV 360x180....
by klausesser » Fri Jan 03, 2014 9:11 pm
Destiny wrote:The clone tool is a silly tool to use.
Wrong. :rolleyes: :rolleyes:
George Randy Bass
by George Randy Bass » Fri Jan 03, 2014 10:17 pm
Thanks Destiny.
I have replaced the RLS tour with the pano that you removed the shadow from. Very large file! Original was 14.3mb the new file is 72.1mb. How will the large size file effect the loading of the tour.
Liked in: 227 posts
by Destiny » Fri Jan 03, 2014 11:14 pm
Thats due to being a TIF, I sent it to you with full data.. When you build your tour, it will be optimised to jpg.. Not an issue...
Users browsing this forum: No registered users and 9 guests
