Panotour pro 2 RC crashes on built
ArneAlbers
by ArneAlbers » Mon Dec 23, 2013 5:45 pm
Hello everybody,
after updating to the latest version of ptp (2.0 RC) the program crashes when i try to build my tour.
This is quite terrible, because i need this to work...
I was successful using all other versions of ptp.
ArneAlbers
Re: Panotour pro 2 RC crashes on built
by ArneAlbers » Mon Dec 23, 2013 6:06 pm
I found out that this happens only when i use the floorplan-plugin...
by mediavets » Mon Dec 23, 2013 9:35 pm
ArneAlbers wrote:I found out that this happens only when i use the floorplan-plugin...
I managed to open a project originally created with beta 5, added a single-level floorplan, and completed the build of the tour.
PTP 2.0 RC1 64-bits on Wiindows 8.1 Pro.
by Destiny » Mon Dec 23, 2013 9:54 pm
Did you add the Floor Plan Patch to RC1..
by mediavets » Mon Dec 23, 2013 10:02 pm
Destiny wrote:Did you add the Floor Plan Patch to RC1..
Not yet...no.
by Destiny » Mon Dec 23, 2013 10:06 pm
You need to ... ;)
viewtopic.php?f=92&t=20883
Please advise if its ok after you have added this patch....
by Destiny » Mon Dec 23, 2013 10:49 pm
Hi.. I have just tested the RC1 Floor Plan Patch, for me its not working 100%.. Its not defined, meaning some xml code is not written right or missing..
Destiny....
the707
by the707 » Thu Dec 26, 2013 7:00 pm
I have been testing PT2 RC1 on my Mac with good results and a handful of bugs I felt I could live with temporarily. After paying for the upgrade and registering PT2 I can no longer "Build" a tour via FTP. The blue progress bar appears with text and then disappears and turns white rather quickly each time. After waiting nearly an hour several times - hoping that it might actually be uploading and just the progress bar is "broken" the tour was not updated at all.
I do not have a floor plan on the tour, if that matters.
Obviously this is a fatal error in the sense that if I can't update or upload my tour the product is useless. I eagerly await an expedient fix or rapid refund.
Sincerely,
Patrick
by mediavets » Thu Dec 26, 2013 7:55 pm
the707 wrote:Hello,
Sincerely,
Patrick
You could use a third party FTP program to upload your tour as a workaround for now.
by Destiny » Thu Dec 26, 2013 7:56 pm
Hi..
Kolor might not be back until Monday, not sure.. First, suggest you try running PTP in 32bit. If that does not work I suggest you do is uninstall your PTP, reboot and reinstall.. It should not be as unstable as you suggest your copy is..
Are you running Windows or Mac..
the707
by the707 » Sun Dec 29, 2013 11:29 pm
mediavets wrote:
the707 wrote:Hello,
Sincerely,
Patrick
Indeed I could.
As a webmaster since 2000 I could also just use KR Pano as well. Instead, I paid money for this program to speed my production process and avoid using multiple software programs to build a tour. While I appreciate the helpful work-around I would expect a solution from the company for the failure of this fundamental feature.
I don't mean to be pointed with you, I am just frustrated with the quality of this "release candidate" product, and that we are paying to be beta testers (other companies provide beta testers with a free license for their troubles), and the lack of acknowledgement by the company which is likely due to the fact that they have chosen to collect bug reports via a public forum.
I do understand the and appreciate the process of software debugging as I myself work for a small but well known photography software company in Europe. With that said, I don't find any of my previous complaints to be acceptable for a "reputable" company.
Sincerely,
Patrick
by mediavets » Mon Dec 30, 2013 1:15 am
the707 wrote:[and the lack of acknowledgement by the company which is likely due to the fact that they have chosen to collect bug reports via a public forum.
Patrick
In this instance it may be because they are on Christmas holidays?
You reported this problem on December 26.
by benji33 » Mon Dec 30, 2013 10:17 am
the707 wrote:The blue progress bar appears with text and then disappears and turns white rather quickly each time. After waiting nearly an hour several times - hoping that it might actually be uploading and just the progress bar is "broken" the tour was not updated at all.
I've reported the problem for internal tests.
the707
by the707 » Mon Dec 30, 2013 6:14 pm
Patrick
Yes, it seems you are quite right. As I see now that they have acknowledged and are actively working on many of the bugs in this forum.
So my mouth is open and I have firmly inserted my foot ;)
