Cannot Create Website Boxes with html text
jschrader
Liked in: 3 posts
by jschrader » Fri Dec 20, 2013 3:28 pm
For me it is no longer possible to create a website box to display html text.
The box appears but remains blank. Local and from a server as well.
The same box displays weblinks, so nothing wrong with the implementation.
Anybody to confirm this?
Likes: 82 posts
Liked in: 184 posts
Re: Cannot Create Website Boxes with html text
by benji33 » Fri Dec 20, 2013 3:55 pm
As in the screenshot you have to add a relative url to access the file.
For instance "./test.html" for an html file near the template html file.
This happens since the test of URL. A bug is reported to verify if it's a file.
jschrader
Liked in: 3 posts
by jschrader » Fri Dec 20, 2013 4:19 pm
That wasn't the case in recent versions!
I spent the entire afternoon to find out what's wrong!
You told me the files have to be in the same directory as the initial html.
If I do so your ./ still doesn't work because it has to be ../
Seriously ...
Liked in: 226 posts
by Destiny » Sun Dec 22, 2013 1:37 am
../ is a common syntax used where files are within the same file structure... However, you would be better off adding the full url even if its in the same file structure..
jschrader
Liked in: 3 posts
by jschrader » Sun Dec 22, 2013 4:26 pm
Of course I know this syntax, but if I remember correctly in previous version this wasn't needed.
So I was under the impression that something else went wrong and spent hours debugging.
Liked in: 226 posts
by Destiny » Sun Dec 22, 2013 4:40 pm
It probably wasn't needed in 1.8 since the file structure is different.. Now there are other sub folders....
jschrader
Liked in: 3 posts
by jschrader » Sun Dec 22, 2013 6:43 pm
We're talking about PTP2 Beta 4 or 5 where I had implemented it in my tour and then with RC1 wasn't working any more. Anyway, it's al history, and I don't care any more. Project is almost finished.
