Memory consumption
ahosny
Memory consumption
by ahosny » Thu Dec 19, 2013 7:15 pm
Hi, while working on Panotour 2 I noticed it is consuming a lot of memory, you can imagine it was consuming 4.3 G.B from RAM while building virtual tour ( 62 images ) ... I wonder is that expected behavior.
Likes: 13 posts
Liked in: 115 posts
Re: Memory consumption
by bdd » Thu Dec 19, 2013 8:54 pm
ahosny wrote:Hi, while working on Panotour 2 I noticed it is consuming a lot of memory, you can imagine it was consuming 4.3 G.B from RAM while building virtual tour ( 62 images ) ... I wonder is that expected behavior.
Yes it is the expected behaviour.
When you launch Panotour, it looks for the available memory at this time, and it takes a percentage of this memory, to ensure to be able to work on big tours or big panoramas.
You can parameter the percentage it takes in the Preferences window of Panotour.
dvande
by dvande » Sat Dec 21, 2013 6:13 pm
I am seeing memory issues with the RC1 release. Win 7 64bit 8gb ram. Each time I build a tour additional memory is allocated but never released. After several builds all the memory is in use and the system becomes unusable until PTP is stopped and restarted. I have configured the memory used preference to the minimum. I think it is caused by having several flat photos as panorama scenes with the output projection set to planer. I have not seen the issue in tours with all spherical scenes.
Another issue is that I have scene descriptions that appear correct in the built tour but what I see in the description window of the properties display is either missing or wrong (text from a different scene). This is an attempt at recreating a vintage tour from 10 years ago, that's why the photos are poor.
And one more thing - I need the compass setting for planer photos so that a radar cone can be displayed on the floor plan.
The tour can be seen at http://www.360tour.us/test
Likes: 13 posts
Liked in: 115 posts
by bdd » Sat Dec 21, 2013 9:32 pm
dvande wrote:And one more thing - I need the compass setting for planer photos so that a radar cone can be displayed on the floor plan.
Thanks, for the report of the memory issue on flat panoramas, we will check it.
Flat panoramas do not have a valid fov, a cone/radar cannot be created on them. If the cone angle represents the fov, then on flat pano this cone is reduced to a single line.
dvande
by dvande » Sat Dec 21, 2013 10:20 pm
It would be nice to be able to spec a fake cone and set the direction of the view for the viewers sake.
