Descriptions bug
karolski_tomasz
Descriptions bug
by karolski_tomasz » Tue Dec 17, 2013 4:02 pm
I noticed a problem with the descriptions, the idea is that when you add descriptions to your project, groups of panoramas and panoramas and off the program and open the project in Panotour not see the names, but descriptions exist, because when you export a virtual tour descriptions are visible.
Liked in: 227 posts
Re: Descriptions bug
by Destiny » Wed Dec 18, 2013 1:08 am
Do you mean when you are viewing your Tour on your workstation, the Description cannot be seen but they can when you upload them to a web server.. If so, the Description feature is JavaScript based, so therefore the Tour needs to be viewed when posted on your web server or you can see a preview by clicking on the Green Arrow test Tour option..
karolski_tomasz
by karolski_tomasz » Wed Dec 18, 2013 11:13 am
Thank you for your interest
no no I mean that you can not see the description on the local machine, because I know that it must be a web server, only that Panotour Pro after loading a project where previously entered descriptions, these descriptions are not displayed,
but the problem is already solved. The idea is that when you copy text from MS Word and paste the description in the Pano Tour, copy is also different styles, as always happens when copying from Word, eg on a website, there is a lot a mess in the code. Do not forget to copy the text to the description of a simple editor, I was copying text from word to notepad + +, then Notepad + + to describe the Pano Tour.
