HTML5 Support for Planar Panoramas
osamaaf
Liked in: 5 posts
by osamaaf » Wed Dec 11, 2013 8:05 pm
When are you releasing support for Planar Panoramas in HTML5 output? We really need this.
Likes: 84 posts
Liked in: 186 posts
Re: HTML5 Support for Planar Panoramas
by benji33 » Thu Dec 12, 2013 1:03 pm
Next release should give you this improvment.
osamaaf
Liked in: 5 posts
by osamaaf » Thu Dec 12, 2013 9:18 pm
benji33 wrote:Next release should give you this improvment.
When would this be coming? I mean in how many days or weeks approx.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Mon Dec 16, 2013 9:10 am
Probably in this week.
osamaaf
Liked in: 5 posts
by osamaaf » Mon Dec 16, 2013 9:24 am
benji33 wrote:Probably in this week.
This is great. I have a work to deliver where I really need this. Thanks and waiting!
osamaaf
Liked in: 5 posts
by osamaaf » Wed Jan 22, 2014 10:52 pm
@Kolor please help!
The HTML5 compatibility has been provided for planar panoramas but multi-resolution is not supported which makes the Large-format images and Gigapixel panoramas just like a simple image without any capability to zoom in.
Moreover since, I m using the html5 to output the virtual tour for offline viewing in a DVD (with the floorplan and everything working), I cannot have the planar panoramas work with multi-resolution. In the flash one, the zoom function using the mouse scroll, does not work offline.
Really in a problem to view the tour offline with all functionality!
by mediavets » Wed Jan 22, 2014 11:29 pm
osamaaf wrote:@Kolor please help!
Kolor has explained that implementing multi-res for large partail panos iusing a spherical projection is currently impractical because it would result in the generation of very large numbers of unused tiles.
Are you using an offline web server?
osamaaf
Liked in: 5 posts
by osamaaf » Wed Jan 22, 2014 11:48 pm
Kolor has explained that implementing multi-res for large planar images is currently impractical because it would result in the generation of very large numbers of unused tiles.
Actually I m not using any webserver and do not want to use one either a my clients want to have the tour burned on a dvd that could be distributed. So what shall I do?
by mediavets » Wed Jan 22, 2014 11:50 pm
osamaaf wrote:Actually I m not using any webserver and do not want to use one either a my clients want to have the tour burned on a dvd that could be distributed. So what shall I do?
Offline web servers are designed for that type of applicatiion.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Jan 23, 2014 10:20 am
Available miniServers are MAMP for MacOS / Server2Go and Uniform Server for Windows.
Also krpanoTestingServer for Windows and MacOS.
Z-WAMP and XAMPP can be used too.
Multires on planar panoramas should work on html5 player. Only partial sphere are not displayed into multires.
