Projections Bug
Likes: 3 posts
Liked in: 215 posts
Projections Bug
by Destiny » Sun Dec 08, 2013 1:20 am
Mac - Beta 5
The Projections seem to not know what view it is..
http://www.destinyvirtualtours.com/PTPV ... AView.html
Re: Projections Bug
by mediavets » Sun Dec 08, 2013 1:30 am
Destiny wrote:Mac - Beta 5
Normal view and Architectural view seem to be the same?
Likes: 3 posts
Liked in: 215 posts
Re: Projections Bug
by Destiny » Sun Dec 08, 2013 1:36 am
Ya, but if you click on others that changes.. That is why I assumed Architectural View to be the Default View.. Its not.. Its depends on which view it is in as to which view it goes to.. It not consistent... Its a bug...
Re: Projections Bug
by mediavets » Sun Dec 08, 2013 1:41 am
Destiny wrote:Ya, but if you click on others that changes.. That is why I assumed Architectural View to be the Default View.. Its not.. Its depends on which view it is in as to which view it goes to.. It not consistent... Its a bug...
OK... and I cannot see a way to set any particular projection as the default can you?
It appears that Normal will always be the default but the projections plugin offers the user the optiion of selecting from a number of alternative projections (the projections available determined by the tour designer via plugin options).
Likes: 3 posts
Liked in: 215 posts
Re: Projections Bug
by Destiny » Sun Dec 08, 2013 2:21 am
No, it seems that the so called Normal View is the default view, what ever that is.. There needs to be an option to set the default view.. I am sure that would be an easy fix...
I had a look at the xml code and found that the Pannini is almost the same code as the Stereographic so not sure how that works.. If I click on the Fisheye Ball, that seems to do some strange thing when returning to other views.. There is something weird.. I bug I suspect.. I think where I marked in red this should be set to false... Its been set to true on both.. Also, the if statement is I think wrong.. They are both set to false.. I think it should be true...
The Normal view seems to contradict itself... or its not complete.. But I am not sure..
</action><action name="setViewNormal">
tween(view.fovmax, 150.0, distance(179, 1.00), easeoutquad);
tween(view.architectural, 0.0, distance(1.0, 0.45), easeoutquad);
tween(view.fisheye, 0.0, distance(1.0, 0.45), easeoutquad, set(view.stereographic,false); set(view.pannini,false); set(display.flash10,on); );
</action>
<action name="setViewPannini">
set(display.flash10,off);
tween(view.architectural, 0.0, 0.25);
set(backtonormalfirst,false);
if(view.pannini == false, set(backtonormalfirst,true) );
if(view.stereographic == false, set(backtonormalfirst,true) );
if(backtonormalfirst, tween(view.fisheye, 0.0 ,distance(1.0, 0.25), easeoutquad, WAIT); );
set(view.pannini, true);
set(view.stereographic, true);
set(view.fovmax, 150);
tween(view.fisheye, 1.0, distance(1.0, 0.75), easeoutquad);
</action><action name="setViewStereographic">
if(view.pannini == true, set(backtonormalfirst,true) );
set(view.pannini, false);
</action>
Likes: 60 posts
Liked in: 169 posts
Re: Projections Bug
by benji33 » Mon Dec 09, 2013 10:19 am
I add a report to correct these features if boolean values are not correctly replaced.
